Question about Zanussi Ovens
My zanussi modele is 241200 / 01 i'm searching for electrical map to fix the termostat because there was some fire in my zanussi can you help me with this problem thank you bast regard my e-mail ali-da62@hotmail.com
3 Suggested Answers
  • 4 Answers
SOURCE: lincoln impinger 1050 ( gas and electric)
pilot is on auto ignite sequence you have a big problem
Posted on Apr 27, 2009
  • 42 Answers
SOURCE: Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Posted on Sep 28, 2009
Our ancient Zanussi ZSA15 oven isn't working. Everything else is - lights grill etc. Guess it sounds like the element around the fan. Can I fix this (unlikely), is it worth replacing?
ONCE AGAIN, A SIMPLE GOOGLE SEARCH!
I WISH PEOPLE WOULD LEARN TO USE IT INSTEAD OF BOTHERING US!!!
Zanussi ZSA15 oven parts
Google
This is the official Zanussi parts website.
Click on Cooking then select heating elements.
Official Zanussi Site Parts Accessories for Appliances
You'll need to find your Appliance Product Number, the page tells you what to look for.
On this website, your ZSA15B or ZSA15W (probably stands for black or white) Is listed. It lists 3 different replacement elements.
Zanussi ZSA15W Elements
Sep 21, 2016 | Zanussi Ovens
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
I can not find a manual for model number ZE0505X
Susan, in what country did you buy the oven? The codes differ per country.
Does the model tag look like this?
Of course it might be difficult to FIND the tag...
Let me check where they stick those....not-find-manual-model-number-ze0505x-cluqxvqmjdhmibjs3bae0uvv-4-2.png
See above location in red.
You can lookup manuals on zanussi.com by using the PRODUCT CODE as well (the serial number does not help). Check if the product code gives you a result on this page:
http://www.zanussi.co.uk/Support/Manuals/
May 18, 2015 | Zanussi ZHQ575 Electric Double Oven
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
MikeandI have just purchased a Zanussi electric oven model no.ZCV550MXC but can't find in the instruction book how long to preheat the ovens for Can you help?
Your best solution for this and all the other problems you may have as a result of losing your manual, is to go to http://www.zanussi.co.uk/node182.aspx put in your model number, hit return and click on the PDF manual it offers you. Then you will have an answer to all your questions.
Feb 09, 2011 | Zanussi Ovens
ZANUSSI Oven E025
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 15, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
Can i purchase a replacement seal for around the
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
Apr 25, 2010 | Zanussi ZBF260 Electric Single Oven
Replace oven doors and front panel
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your parts , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Zanussi ZHQ575 Electric Double Oven
Zanussi oven not heating
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
95 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
