Question about Canon ES8600 Camcorder
Moving recording into the computer
Although the camcorder uses an actural tape, I was wondering if there was a way I could just connect the camcorder with the tape still in it to the computer and then save the recording on the computer instead of feeding it into the television
    Scholar:
  • 31 Answers
You need a USB video capture device. This will connect to the USB port on your computer and will connect to the video and audio out on your camera. These devices come with there own software and its pretty simply to use. I also see that the price has come down on these devices. I bought one a year ago and was around $ 70. Now you can find one for around $ 20. Here is a link which has a bunch of them for sale. http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=usb+video&x=15&y=22
I hope I have been helpful and if you need any help keep posting
Posted on Mar 18, 2009
5 Suggested Answers
JoeO700
  • 80 Answers
SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Posted on Mar 01, 2007
SOURCE: Panasonic PV-DV52 Tape Feed Problems
So I totally had the exact same problem, tape jam, then the blinking power light. I took the case off ( was about 8 or 9 screws). Took a look at all the pretty ribbons inside. Put the lid back on...and guess what...it works!!! Must be some kind of internal reset maybe? who knows...saved me from buying a new one though.
Posted on Sep 20, 2007
  • 73 Answers
SOURCE: camcorder wont playback
SOUNDS LIKE YOUR CASSTEE COMPARTMENT IS BAD.. TRY CLEANER CASSTEE.. MAYBE THIS WILL PROLONG THE AFFECT. LET ME NO IF THIS HELPS
Posted on Mar 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sep 29, 2010 | Sony 8mm Stantard Grade 120 Minute...
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
How do I transfer recordings from tape to dvd?
If this is a Dig8 camcorder, it should have a DV jack. From this, you can use an iLink cable (firewire cable) to plug it directly into your computer. If you have a DVD burner on your computer, this should work for you.
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
www.austintelstarservices.com
Sep 03, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Canon ES8600 Camcorder Logo
95 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
