Question about Bosch SHU5316UC Dishwasher
Just had a Bosch dishwasher installed in my new kitchen. The plumber who installed it ran it and it worked. Now we cannot get it to run. We have tried everything. Restarted several times, turned the circuit breaker off and on, changed the cycle and nothing works. The light comes on but it does not get water or run. What are we doing wrong. The dishwasher is brand new out of box but we bought it 4 years ago and remodeling was delayed. Model #SHU5314UC/U06 FD#8001
  • rmumma Oct 11, 2010
    I did not replace a dishwasher. This is the first one in this house. I do not understand much of what you are saying to me. I am not a plumber and I did not install the dishwasher. Could you repeat that in baby step terms. Sorry. I DO appreciate your attempts at helping
  • rmumma Oct 14, 2010
    It has been so long that we solved the problem ourselves. We no longer need help.
    do not charge my credit card.
    Rosemary Mumma
  • 11,896 Answers
Test the door switch. It can be faulty or misaligned. You can also check the back of the unit and/or remove the rear panel and take a look at the thermal fuse. It may be bad not allowing enough current flow to operate the machine.
Posted on Oct 15, 2010
    Brigadier General:
  • 3,513 Answers
The jumper plug must be there if it was on the old one. Also it is very important what kind of detergent did you use. Such dishwashers do not work with any kind of liquid or jell detergents and you have to use a rinse aid. Water enters the dishwasher via an electronic valve, also there is also a filter where the hose enters the valve, but as you have already disconnected the pipe connected to it you would have seen any obstruction. The valves are pretty cheap and pretty easy to replace, it usually consists of removing the lid and disconnecting a couple of wires with spade clips on them, undoing a couple of screws to remove the valve, then just replacing it and reconnecting the wires.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 11, 2010
  • Bosch Master
  • 43,501 Answers
The first thing I can think of is that for some reason the plumber turned the water back off after running the dishwasher and forgot to turn the water back on.
The water is often hooked into the hot water pipe right under the sink...see if there is a valve there going to the dishwasher and make sure that it is on...
The other thing it could be is that sometimes the plumber will use a hose to hookup the dishwasher...this hose could have kinked and stopped the flow of water to the dishwasher....
this would probably be under the dishwasher behind the kickplate and be out of site without removing the kickplate.
Another possibility would be that a wire got knocked off of the solenoid valve when the kickplate was reinstalled.
The best thing would probably be to call the plumber back and get him to come out and troubleshoot his work...believe me I have had to return to places over the years for some pretty crazy stuff, but I always feel it is my responsibility to make sure that the customer is totally happy with my work...
Good Luck!!
heatman101
Does anyone have installation instructions fo a Bosch free standing dishwasher smu50E65au? Thanks. Julie
Hi Julie.
A dishwasher needs access to water numerous times during it's cycle. You'll have to have the hose on the tap with water pressure on while the machine is in operation. You could exchange your tap for one with thread or install a second one behind the current one.
(Slightly agricultural repair)
When installing a dishwasher the drain hose outlet MUST be above the water level in the machine or the water will run out as soon as it is put in...They usually connect to the S bend under the sink.
It would probably be best to have a handyman/plumber attend to the job.
Good luck
Nomess
Jan 31, 2015 | Bosch Washing Machines
My bosch dishwasher has a terrible from day one. I have tried running vinegar through a wash cycle. My dealer I need to run it a few times. I have had this machine for well over a year and still gives...
Hello and welcome to Fixya.
It "smells" ( just kidding ) like you might have a problem with the way your drain hose is connected by your description.
It is crucial that your Bosch dishwasher have a siphon break or "hi-loop" installed in the drainage between the dishwasher and where it enter's your homes plumbing.
If it does not you can try different cleaners until the cows come home with little effect because the odor is coming from the drain line itself.
Was this unit installed by yourself or someone you know ? Or was it installed by a plumber/professional installer.
In the end it actually makes little difference, I'm just curious. I see professional installers as well as plumbers fail to include this crucial feature over and over.
Let me know. I'll watch for your post. If you are unclear as to what I'm referring to, check your installation guide that comes with all Bosch dishwasher's.
If you do not have any instructions regarding the proper drain/install I can email you a copy, but I would need your email address.
Good luck.
macmarkus :)
Jun 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch dishwasher that was working just fine until I spilled a bag of uncooked pasta. I sent the pasta down the drain and ran the garbage disposal, subsequently clogging the pipes. I had to get a...
It may simply be where the dishwasher drain attaches to your garbage disposal. There should be a hose clamp and can easily be taken off. If the clog's not right at the connection, chances are it's far. If there is an air gap, it will be within a foot of the connection. Just shake the DW drain into a bucket and you should be good to go. Not sure why the plumber wouldn't do that though....being a plumber, I would never leave a customer with a clog. Anyway, good luck!
Jan 24, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
I bought our bosch one year ago in aug.but not instoled until my kitchen was finished in oct.2008 now it's not running well at all itnot cleaning it just runs with nothing happening?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syew
Oct 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Just had bosch dishwasher installed by plumber but it is still not filling up with water. it works after we poor a pot of water in it.
Locate the hot water supply hose under the sink that connects and follow it over to where it will connect to the back of the dishwasher. Look for sharp bends in the hose. There should be a valve where the hose connects to the under-sink plumbing. Rotate that valve counter-clockwise to assure that it is open.
If the problem continues, the solenoid valve may have immediately failed. That valve is just behind where the hose connects to the dishwasher.
Good Luck!
May 08, 2009 | Dishwashers
Dishwasher insulation for heat
Hi marseibold,
I'm Harvey the Master Plumber.
Your questoin is: You're wondering if you can further insulate your dishwasher for heat. You are redoing your kitchen, new appliances, cabinets, etc. and shortsightedly put the spice sliding pull-out cabinet next to the dishwasher. The spices get warm when you use the dishwasher. There is a bit of room between the cabinet and dishwasher. Any recommendations for further insulation?
Yes. I would get another insulation blanket off a d/w I'm disposing. Anyway, you need to get one and install it over the old one to decrease the heat transfer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
My Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. I have put through a dishwasher cleaning...
Hi shanandpop
Your question is: Your Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. You have put through a dishwasher cleaning solution, but find it isn't doing anything to resolve the problem?
You're still under warranty. The best advice is to use it. If it is not fixed the first time out, demand a new one from where you bought it. Sometimes they drag this out till the warranty runs out, then where will we be.
Thank you,
Sep 11, 2008 | Bosch Dishwashers
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU5316UC Dishwasher Logo
113 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
