Question about Garden
Looking for any information on a Busybee milling machine part number B314
Looking for a Elliott 70 Milling machine manual
that is general info about milling machines and what to do with them:
http://team358.org/files/mechanical/HowToUseAMillingMachine.pdf
if i recall - yours is about 40 or 50 years old, i did search through my contacts and nobody have this particular manual... sorry...
if you find it - please publish it for rest of us! thanx in advance
Jan 06, 2015 | Tools & Hardware - Others
Are there automatic grain mills? I've only been seeing hand mills on Amazon.
Most of the mills that you will see on sites like amazon are hand mills but I found the Nutrimill to be a really amazing machine mill, its quiet and quick and has many different settings. EQUIP Nutrimill Grain Mill Amazon com Kitchen Dining
Jan 23, 2014 | Kitchen Appliances - Others
Whats the difference between a vertical and horizontal mills?
Horizontal and vertical just refers to the orientation of the spindle, each has their advantages and disadvantage, the vertical mill is more for standing mechanists and doing more detailed work while the horizontal are designed for cutting heavy pieces.
Jan 23, 2014 | Tools & Hardware - Others
What is gang milling? Do I need a special milling machine?
Gang milling is the term used for using multiple milling cutters mounted all on the same arbor. If you have a horizontal miller then you shouldn't need to get an other one.
Milling machine problems and solutions
I'm going to assume you mean metal, since on wood it is called routing.
The number one problem would be insecurely fixed work pieces. Work out which way the cutting force goes, and try to have that directed to a solid part of the setup, not to a moving jaw or clamp.
Make sure your cutter is sharp. Blunt cutters generate enormous forces which can become dangerous. I have seen cutters shatter in this situation.
Know your cutter type and what it is capable of. Some types cannot do a heavy feed rate. Know your material and what it requires. Stainless steel for instance is treacherous because it hardens in the cut.
Use some kind of cutting fluid even if it makes a mess. Milling is a process which needs it, and you will get a better finish.
Never never put your fingers near the rotating cutter. I saw an apprentice mill his forefinger off once. He was feeling the surface finish behind the cutter.
Nov 28, 2013 | Tools & Hardware - Others
Whats the difference between a milling machine and a drill press?
a drill press holds the work piece stationary to be cut, a milling machine moves the work piece to the milling cutter.
Jan 23, 2013 | Tools & Hardware - Others
Need a supplier for a drive belt for a bridgeport varidrive milling machine I cant seem to find a supplier or a part number anywhere
Take the old belt to a local power transmission dealer in your area. Those types of outlets offer various parts such as the various belts needed for industrial equipment. Even without a number on the old belt they should be able to type and cross it based on dimensions, angles and overal length.
John
Dec 15, 2010 | Jet Equipment & Tools 690182 9 X 49 R8 3...
Cooks essentials CEMB10TC help cant find one
Have the 10 cup mill and brew with metal carafe....like new and selling for $25.00 plus shipping.
Dec 16, 2009 | Cook's Essentials CEMB10TC
Looking for manual for a Jet-16 3-phase machine for drilling and milling that I bought
GO ONLINE AND TYPE IN / JET 16 MILLING NACHINE MANUAL
THE PAGE YOU WILL NEED IS ASAVAGE.DYNDNS.ORG/JET 16
AND CLICK ON THE MANUAL IT'S 19 PAGES
Sep 26, 2009 | Jet 708531 Jwp 16OS 16 Inch 3 Horsepower...
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
