Question about Yamada DVD-5520 DVD Player
When i use the zoom x2,to fill the screen the x2 logo remains on the screen,how do i remove it?.i have tried all buttons on the remote.
  • Yamada Master
  • 6,993 Answers
the X2 button cannot be removed when it is pressed, it will certainly remain on the screen of your TV because that's how it was made.
But you can try this, look for OSD (on screen display) on your remote, if you find it, press it severally, and if doesn't remove it, then there is nothing you can do.
Good luck.
Posted on Oct 11, 2010
I have a Soyo 26" and no manual. The problem I am having is that the image does not fill the sceen, does any one have a solution?
check its remote there would be a zoom button on it. with wish you can zoom the image. every time you press that button the screen will change like X2,X3,X1/2 etc. Select the normal mode.
http://electro-medical.blogspot.com/
Nov 11, 2015 | Soyo 26 in. LCD TV
RCA 2004 year ModelD52W15B
Check the remote there would be a zoom button. Every time you press the button the screen of the Tv will change just like X2,X3,1/2X ect. select it to normal mode or OFF.
Nov 06, 2015 | RCA Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Picture Zoomed in too much, no zoom button
I had the same problem after plugging my pc into the pc-in socket. The problem happened with the scart connections after.
I solved it by turning the tv off/on from the wall plug socket.
Mar 06, 2010 | Televison & Video
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
2x logo remains on picture
i have the same problem. i finally went to "setup", "video" and selected "16:9". it doesn't fill the whole screen but it is better.
Dec 19, 2007 | Televison & Video
Picture size
They may have gotten to the zoom function. There is a zoom button on the cncealed part of my remote. Hit the zoom button to cycle through all the screen sizes.
Oct 26, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Open Questions:
Yamada DVD-5520 DVD Player Logo
Top Yamada Televison & Video Experts
Are you a Yamada Televison and Video Expert? Answer questions, earn points and help others
