I need to replace an assembly in my copier, however, I don't know what it is called or where to order it. It is held in with four screws. It has two rollers and a heating element.
    Genius:
  • 1,218 Answers
Sounds like you are describing a "fusing unit" ( the section that melts the powder onto the paper.) you dont mention make or model so look in the Yellow Pages of your phone book under "copying" for a dealer who services the make of machine you have.
Posted on Oct 12, 2010
Is the throttle assembly on a John Deere GT275 held onto the dash by only one screw?
This is possible. Throttle may hold on one side with a protrusion on one side and the screw on the other side. They are also designed to snap into place with nothing but possibly FOUR protrusions, which would have to be bent away in order to remove throttle. GOOD LUCK FRIEND.
Sep 23, 2014 | John Deere Garden
How to remove bumper
1. Remove rear combination light assembly. A. Remove two mounting screws. B. Disconnect electrical connector from rear side of light assembly.
2. Remove bumper assembly. A. Remove four fasteners and four retaining screws from top of bumper assembly. B. Remove mud flap from bumper assembly. C. Remove two screws from bottom of bumper assembly. D. Remove two screws from side of bumper assembly. E. Remove four bumper mounting bolts from under of vehicle.
3. Install rear bumper in reverse order of removal.
Dec 22, 2013 | 2004 Kia Sedona
How do I replace ATDC Sensor
Hi ordered a replacement servisakov call and they'll assemble free of chargeHi ordered a replacement call and they'll assemble free of chargeHi ordered a replacement scall and they'll assemble free of chargeHi ordered a replacement serviceman call and they'll assemble free of charge Hi ordered a replacement servisakov call and they'll assemble free of charge Hi ordered a replacement servings call and they'll assemble free of chargeHi ordered a replacement servings call and they'll assemble free of chargeHi ordered a replacement servings call and they'll assemble free of charge.
Oct 06, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
I need to replace the gas bubble on a McCulloch Power Mac model 600032-54.....32cc i don't want to break the plastic ring around the bottom that holds it.. Thanks
If its a remote primer, it is sold as an assembly and just clips into the tank, if it is on the carb itself it will be retained by the metering cove of the carb held with four screws.
Jun 20, 2012 | McCulloch Garden
Where is the heater blower resistor located in a 2000 Subaru Outback? I've seen one reply in a forum saying it is to the left of the blower motor, but I don't know where that is either. I need to...
the blower motor is located under the passenger side of the dash. The blower motor resistor is located behind the glove box assembly. You will need to remove the glove box assembly and then you will see the resistor. It will have one connector with four or five wires and will be held to the HVAC unit with 2 screws.
Jun 23, 2011 | 2000 Subaru Outback
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
Engine cooling fan has quit working ? at first it wouldn't shut off and now it wont stay on
this is going to sound crazy but remove the passenger side headlight you will see the bucket assembly that the light sits in it,s plastic at the bottom of light bucket trim out a little hole about three or four inch square once removed you will see the fan relay held in by two screws if you don,t cut hole for access you will have to remove front bumper cover assembly alot of work and the hole deal is better it does,nt hurt a thing once headlight is back in you will never know little hole is there this is a tremendous time saver hope this helps
Jul 30, 2010 | 2002 Jeep Grand Cherokee
Whirlpool dishwasher adp 962 - rinse aid/soap assembly
Hey- Tag should be visible with door open, left side. MOD.   Let's go over replacement instructions. Turn off power The door panel is held together by T20 torx screws. Remove screws, unplug the wires, and take off panel. Door is spring loaded, so place some weight on it to keep it down. Four 1/4" screws hold dispenser in place. Replace and re-assemble. Not too tough- just beware sharp edges! Let me know if this info helps- have more if needed- Thanks- Ed
Mar 17, 2010 | Dishwashers
How to remove the rear bumper on a 2005 Kia Sedona
1. Remove rear combination light assembly. A. Remove two mounting screws. B. Disconnect electrical connector from rear side of light assembly. bs6d007a.gif 2. Remove bumper assembly. A. Remove four fasteners and four retaining screws from top of bumper assembly. bs6d007d.gif B. Remove mud flap from bumper assembly. C. Remove two screws from bottom of bumper assembly. bs6d007e.gif D. Remove two screws from side of bumper assembly. bs6d007b.gif E. Remove four bumper mounting bolts from under of vehicle. bs6d007c.gif 3. Install rear bumper in reverse order of removal.
Nov 09, 2009 | 2005 Kia Sedona
Real right turn signal light - Pontiac Montana SV6 2005
If the 2005 Montana is similar to the 2001 Montana, I have a solution. First you'll need a hexagonal wrench (the 6-sided L-shaped wrench). The tail light assembly is held on by two screws. You'll need the hexagonal wrench to remove them, because a normal screwdriver won't do it. I also had to use a conventional adjustable wrench to get the leverage to turn the hexagonal wrench, because the screws were in there pretty tight. Once you remove the two screws, the whole tail light assembly should come off. Mine required a little force and I had to play with it a bit, but it came off without a lot of work. There will be one set of wires that connects the tail light assembly to the rest of the minivan--try not to damage that set of wires. Once you get the tail light assembly off, you'll have to take apart the assembly that actually holds the lights. No tools should be required. It's held on by four plastic catches. Just undo the catches (easier said than done, but still not too tough) and it comes apart. Then you can pop out the old light and pop in the new light. Then re-assemble. For me, it went back together much easier than it came apart.
Dec 16, 2008 | 2005 Pontiac Montana SV6
21 people viewed this question
jasbo
jasbo
