MY COMPUTER WILL NOT BOOT. IT WORKED FINE 2 DAYS AGO AND WAS POWERED OFF BY ME. CHECKED OUTLET AND CORD. AS I PLUG COMPUTER CORD IN ,I GET A GREEN LIGHT FLASH AS I PLUG IN BUT DOES NOT STAY ON. I ALSO TRIED NEW POWER CORD.
  • iglazer474 Oct 14, 2010
    tried all that you told me to do and still dfoes not start. the green light at top of the powerbox does not light up.
  • 600 Answers
Look for the bios battery on the motherboard,changed them as necessary.near that are three pins with a jumper on pins 1 & 2, remove the jumper and place on pins 2 & 3 for about 30 seconds.
Replace jumper back on pins 1 &2, this will reset bios to system defaults, and would surely counter check the system and hopefully it would boot.
After those steps, try considering reading through this link http://www.pctechbytes.com/repair/detail.php?PC-Will-Not-Boot-6
this would be a step by step guide on how to spot or trace the culprit causing you pc not to boot.
Replace or repair the found culprit upon checking with those steps.
but be sure to perform the steps with the plug(power cord removed from wall socket or power supply-avr) to prevent electrical shock.
hope his helps
Posted on Oct 11, 2010
Laptop has power but won't boot up
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the acer power adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC adapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Feb 13, 2013 | Acer Aspire One PC Notebook
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
WILL NOT POWER ON
Good day. Here are some tips on how to troubleshoot the problem:
1. Check for physical connection first. Check if the power cord doesn't have any physical defects.
2. Make sure the printer is plugged in to a known working
power outlet.
3. Unplug the power supply from the printer(it's the black box
where the power cord is plugged in behind the printer). It may be
hard but it can be removed. Leave the power cord plugged in it and
the other end to the power outlet in the wall. Check the LED around the silver contacts of the power supply. It should be on and green. If that's on, power supply is ok.
4. Plug back the power supply in the printer. Make sure it's
plugged in the right position. It may seem to be plugged in already
but the position is incorrect. Double-check.
5. If you have double-checked already that the power supply is
plugged in correctly 100%, then it should power on.
6. If not, try pressing the power button of the printer.
Hope one these steps fixes the problem. Good luck!
Mar 18, 2010 | Lexmark X5495 All-in-One &USB...
Monitor problem
no that is a problem of microcontroller chip inside the monitor ti becomes faulty because of virus inserted in the monitor and chip bacame faulty try if anywhere it formatted and reprogrammed
Mar 05, 2010 | LG Studioworks 700S 17" CRT Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
The TV will not power on with remote or manual button
Have you had any major power outages in the days leading up to this issue? It could be a power source, cable or outlet. Try different outlets if you can and see the tv responds.
Best of luck,
Al
Apr 18, 2017 | Cyberhome CH-LCTV 150 15 in. LCD...
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Facing No lights at all on router.
How long ago was it purchased? No lights at all would certainly seem to be a power cord issue. There's a possibility there may have been a surge that fried out the router, or the power cord may not be putting out the correct (or any) voltage anymore, but to check that you'd need a voltmeter. Have you tried plugging it into a different outlet to see if that makes a difference?
Sep 16, 2007 | Netopia 3346N-VGx Router (3346NVGX)
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
