Question about Intel S975XBX2 Motherboard
Not getting display on my system after changing some settings in bios motherboard intel S975xbx2
  • nafsal Oct 12, 2010
    thanks for the reply.
    but i have tried resetting bios removing the battery and changing the jumper settings as well.
    but still no display on monitor.
    also i have tried to change the RAM and Graphic card . still cannot fix the problem.
    in bios i have changed the memory override setting from manual to automatic.
    got the problem after this only. i have tried the same setting in one more system with same mother board. got the same problem. no display in monitor. help will be appreciated.
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Disconnect the power-cable.
On the motherboard, locate the battery.
It's silver-coloured, about the size of a US $0.25 coin.
Before you remove it, note the writing on the top.
Remove it.
Wait a few minutes.
Reinsert it, making sure that the noted writing is STILL on the top.
Reconnect the power-cord.
Start your computer, and enter BIOS SETUP.
Click LOAD BIOS DEFAULTS.
Save and Exit from BIOS SETUP.
Posted on Oct 11, 2010
  • 1 more comment
    i have tried resetting the bios reinserting the battery and changing the jumper setting as well.
    but still no display on monitor. i have tried to change the RAM and graphic card to make sure no problem with memory and display. but still having the problem.
    got this problem after changing the memory override setting from "manual" to "automatic" in bios.
    i have changed the same setting in one more system which has the same mother board. got the same problem on that pc as well. a resolution for this problem will be highly appreciated.
  • ikkenom Oct 13, 2010
    Have you tried changing the setting back to the previous value?
    Put two identical systems, side-by-side -- one that does not display, and one that does ---
    and make the same key-strokes on both systems.
  • codykl Feb 26, 2011
    All you need to do is pull the jumper located a bit above the battery, then move it one down and your in Config Mode. In there reverse the changes you made and put the jumper back again...
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
My system is turn off and turn on no loading os and bios is not working motherboard is intel d102ggc2
Have you tried pressing F2 when you powered on the PC?
Ensure that the monitor displays the signal of PC and there is no issue with video signal. If there any issue, check with RAM.
1.If no, just press it to view the bios setting. Go to the third option below.
2.If yes and no display of bios, may be your BIOS ROM chip failed. Before that take the C-mos battery out and try again. Almost try to replace it or you must go for a new motherboard.
3.If yes and getting into bios, check for the hard disk detection. If it is detected, try again for booting. If it is detected and not booting, try to format. If it is not detected, try changing it into another SATA / IDE port. Still it is not detected, replace the hard disk.
Aug 19, 2011 | Intel D102GGC2 Motherboard
Hi, iam ramesh i have problem in my intel 845gvsr , when system boots it displayed error message date & time not set , i have changed new cmos battery.
There are two reasons for this issue
1. It is battery - but you have replaced it. 2. It could be your BIOS is degraded try the following steps
a. Reset your settings to defaults by using the jumper and try b. if the issue still persists you can try installing the upgraded BIOS version (but be cautioned - since failure during BIOS upgrade may lead to motherboard failure).
Mar 09, 2011 | Intel D845GVSR Motherboard
Intel Desktop Board D845BG (KD845BGPAK10) Motherboard display not working
it can be a motherboard fault try resetting your bios. u can rreset bios by changing jumper settings near to the bios
Mar 08, 2011 | Intel Desktop Board D845BG (KD845BGPAK10)...
The CPU my Intel S975XBX2 Motherboard is Overheating at about 67c to 82c with a Pentium d processor clocked at 3ghz (not overclocked)
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Nov 28, 2010 | Intel S975XBX2 Motherboard
BIOS SETTINGS
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Feb 19, 2009 | Intel D845GLLY Motherboard
MY system is not read OS from CD drive
is the bios set to boot from the cd drive 1st?
Jan 20, 2009 | Intel D845GVSR Motherboard
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
BOOTING ON MAINTANANCE MODE BUT NOT ON NORMAL MODE
Clear your bios, remove your all pci cards & then try.
Feb 23, 2008 | Intel D845GVSR Motherboard
No display (intel original 865 ..)
Tell me the Mother Board Chipset & Oper.Sys you are using.
Try to change power settings in bios if it not works try to set bios optimal defaults, if it not you have to update BIOS.
Hope this will be helpful..
Nov 22, 2007 | Intel Motherboard
Intel S975XBX2 Motherboard Logo
75 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
