Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My 24 hp Briggs v twin smokes and uses oil bad. Smoke comes out of the left side when running. Can I use head gasket sealer to get me through the season?
  • 4,349 Answers
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Posted on Oct 11, 2010
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Just started to noticed white smoke coming out of exaust pipe. Noticed smell of gas. Is this normal for a car this old
Looks like you have a blown head-gasket. The white smoke is actually your engine coolant mixing with your engine oil and being expelled as a water vapor. You need to take it into a repair shop Immediately.
Sep 28, 2010 | 2002 Toyota Camry
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
1993 saab turbo CSE. limphome mode, possible head gasket leak
Things can only get get worse and that means more expense. Like mine, better to do the head gasket asap while it's not too expensive or at least get the head bolt torque settings checked after the rebuild as they may need tweeking.
Jul 17, 2009 | 1993 Saab 9000 Hatchback
White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
May 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Blue smoke coming from exhaust
blue smoke out of 1.8 turbo its allways bad oil seal inside turbo.need new turbo or rebuild OEM. with 24 years experience working with vw never seen single headhasket go bad on 1.8 turbo engines.blue smoke its 100% turbo every time
Jul 17, 2008 | 1999 Volkswagen Passat
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
952 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
