Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Copying from upper tray - line on the copy - good copy but has a solid thin line, about the size of the roller.. -- copying from glass is fine..--if it is the roller ! how do I clean upper roller and etc. ?.. Denny My printer is OfficejetPro 8500 A909g wireless
    Scholar:
  • 107 Answers
Hello, you said this was a copy, have you tried making copy from the glass, and not thru the doc feed, just to see if the output us the same. if not, open up the doc feed area, and clean the **** glass. now if your prints from the computer are the same as the copies, then its possible that the problem is pressure rollers above the ashpalt grey platten roller. alittle harder to clean but can be cleaned off.
Posted on Oct 11, 2010
Officejet 9600: vertical lines (4) in center of page when copying using ADF. No lines when copying from glass. I tried the cleaning procedures on your trouble shooting pages. They did not help. How ca
John:
When using the ADF, the scanner doesn't move. The long rectangular platen glass on the left side of the machine is used, not the large glass. I believe that if you clean the long, thin piece of glass on the left side of the platen, your lines will disappear.
May 21, 2014 | HP Officejet Pro 8600 e-All-in-One -...
When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Office Equipment & Supplies
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
Copies are shaded and have a solid black line down
Is this an analog or digital copier?
Multiple things could cause what you describe.
To answer your question rubber rollers can be cleaned with soap and water and a damp cloth.
Hot rollers cannot be cleaned and should be replaced as the teflon coating has failed.
Organic drums should not be cleaned with a cleaner but just a clean dry cloth.
I would look at your mirrors(under the glass) if there is dust on them it will darken your copies and could cause lines.
If it is digital print out a counter if it is a good print the your problem is dirty mirrors and / glass
Apr 13, 2010 | Lanier Office Equipment & Supplies
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
Copying with 4" solid black vertical stripe
what about if you print from computer or do an internal print like a self test? if print looks good on those, you most likely have a scanner problem, which is the mechanism under the glass.
razors
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Nov 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
