Question about Pride Mobility Products Quantum Jazzy 500 Electric Wheelchair - Used
I am loosing green lights on my joystick quantam 600 power chair what could be wrong
    Novelist:
    Champion:
  • 232 Answers
The green lights will gradually go away as your battery is being used, this is completely normal. You batteries should last for around 5-10 miles of use. If you find that your battery light falls into the red after only 2-3 hours of use and you have been charging the batteries every night for at least 8-10 hours, contact your manufacturer for service.
Posted on Oct 11, 2010
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
When i plug the cable into the joystick control (MK5SOJ+) all the lights around the horn button blink on and off motor wont engage and it won't shut off til pull out the cable do i need a
When you say the power cable I hope you mean the cable that comes from the main control module under the chair. I want to make sure you are not talking about the AC power cable that plugs from the chair to a wall outlet. So if we are on the same page about the cable is the one going from the joystick to the main control module under the chair and all you do is plug it in and the green speed lights start to blink this would indicate the joystick is bad.
Jan 23, 2015 | Invacare Pronto M51 Power Wheelchair
Jazzy chair 600 3 red lights 4 yellow 1 green no power both batteries read 12.5
Have the joystick controller tested. Make sure the cable is fully seated in the chair connector.
Feb 17, 2014 | Pride Jazzy 1113 ATS Indoor Power...
My uncle left my hoveround chair out in the rain is this the end of my chair? when i plug in the charger the light on the charger lights up green but the chair wont come on
Angel the charger light should only turn green when the chair is fully charged. If you know the chair isn't fully charged then there is a problem with the charging system. if the circuit board in the joystick got wet then that is a serious problem. If you have a voltmeter you can check the battery voltage thru the charging port located under the front of your joystick Set the meter to 200 volts dc and plug the leads into the 2 outter holes of the charger port. Fully charged you should read 27-30 volts if you aren't getting any reading then the batteries are completly dead or there is a problem with the charging circuit (the reason you are getting a green light on the charger) The joystick will have to be replaced sorry If Medicare paid for your chair then they will pay 80% of the repair costs to get your chair working again If they did contact Roadrunner Mobility @ 1-800-467-2668 to get it fixed thru Medicare Hope this helps
Apr 27, 2011 | NRS Hoveround MPV 5 - Used Power...
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Mobility Products Quantum Jazzy 500 Electric Wheelchair - Used Logo
218 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
