Question about Frigidaire FDE336RE Dryer
Dryer Noise & Black Marks On Clothes
The Dryer is making a loud squeeling sound and the clothes are getting caught in the front of the tumbler leaving black marks on the clothes.
  • seedlings Jun 18, 2008
    FDE336RES2 dryer making banging, growling, screeching noises and also clothes are getting burn marks. I'm still searching for some helpful diagrams... Thanks.
  • revrick Sep 15, 2008
    same problem different model number FDE647RFS0
  • 283 Answers
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
Posted on Jul 17, 2008
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Loud squeaking noise
it sounds like your roller bearings are bad you need to get the top open then take the front off loosen the belt take out the tumbler try to squirt oil on the shaft the rollers are on there should be two of them,put it back together and try it,if that doesn't work replace them.
Dec 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Black marks on white clothes
if it looks like straight pencil lines possible cause is the tumbler in dryer is rubbing metal against metal on the bulkheads usually followed by loud noises check your tumbler and bulkheads
Jun 27, 2009 | Kenmore HE2 Plus Front Load Washer
My clothes are getting caught in my dryer.
I am having this same problem with my GE dryer. I found a post on fixitnow.com from a guy that has repaired these for years. He says it is the rear drum bearing. Looks like a pretty easy fix, I am going to try to do it myself. If you try this, I have also read that you should spend the extra $10 to go ahead and replace the drums front felt glide kit.
http://fixitnow.com/2005/03/field-notes-frigidaire-dryer-front.htm
Good Luck!
Mar 25, 2009 | Frigidaire GLER642A Electric Dryer
Moffat heavey Duty Dryer
Hi and thank you for your request.
Assuming the marks were not there before you put them in the dryer, then there are a couple of possibilities for the marks appearing.
Check that none of the clothes lifters or ribs as they are sometimes called in the drum are not loose, as the clothes could get caught in any gaps,make sure that there is no large gap between the drum front and the front of the dryer, as again clothes could get caught here,,check to see nothing is stuck on the drum itself that could transfer onto the clothes.
Make sure the drum is free to turn and that there is no unusual noise coming from it, if it does appear to be noisier than usual ,then it could be the drum rollers or bearings are starting to wear and this could transfer grease and the like onto your clothes.
Hope these suggestions help with your prob.
Plz feel free to leave any comments and rate my suggestions.
Thanks
Jan 05, 2009 | Dryers
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Mdg4000 GAS
bad rollers could be making black dust but the real problem is the tumblers seals letting the roller dust get into the tumblers and on to you clothes.
Black or brown makers are from the faulty or damaged tumblers seals you have one in the frount and one back...
I can help you strp by step if you want to do it yourself.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
822 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
