Firmware files - Office Equipment & Supplies
    Genius:
  • 1,218 Answers
Go to the manufacturers web site they are normally available for download.
Posted on Oct 12, 2010
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
How do I solve a 49.2f01 error and what could be the problem?
Error 49.2f01 indicated corrupt Firmware, which are Programming instructions that are stored in a read-only memory unit inside the printer and it can be fixed by downloading and the updating the firmware through the following process:
Updating the firmware
Update the printer firmware by loading the new firmware file from the computer. You can find new
firmware files for your printer at www.hp.com. Click here to download latest firmware and firmware updating utility.
1. Open the HP Printer Utility.
2. In the Configuration Settings list, select Firmware Update.
3. Click Choose, navigate to the firmware file that you want to upload, and then click OK.
4. Click Upload to load the firmware file.
Please refer to PRODUCT USER MANUAL (Page-29) before proceeding.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP LaserJet 4700 Printer
The root file of sansa view 8GB is deleated,to copy firmware files????
sandisk has a firmware manger install update manger(firmware manger) and let it do the work if you have internet if no internet still get update manger and put the frimware in C:/program files/??(sandisk folder)/firmware. the restore and it will use that firmware.
Aug 25, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
How do i update the firmware for the VP8870? Ive already downloaded the zip file. All my video files suddenly disappeared! Anyone know why?
While performing firmware update all data will be erased !
See the manual on page 36:
Vosonic VP8870 manual
The firmware update for the player is PMP.VP8870-1.0.0.B2.mtg :
Since you've downloaded the zip file, were you able to unpack it with
Winzip op Winrar ?
When using XP you can unpack by:
1. [Right click on the zip file] Open with > Compressed maps [left click on Compressed maps]
2. The next screen shows the opened zip file. On the left side the
folder task manager can be opened ( Folders / Maps in the top bar not selected): "Unzip all files" : follow up the Windows unzip wizard and
remember the location of the files.
How to do the firmware update is explained in the pdf file "How to update 1.0.0-B2 - VP8870 .pdf", added to the firmware update in the
zip file.
Remember:
Sep 12, 2009 | Vosonic Audio Players & Recorders
Netgear DG836GT
OK. First, that dg836gt_1_02_09.img file does not seem to be a firmware file. You need to get a .zip file or a .bin file to upgrade the firmware. Check Netgear's website for the current firmware. If it is a .zip file, then you need to extract the .bin file from the .zip file with winzip software. Then, log into your router with Internet Explorer by typing it the routers IP address in the address bar like this http://xxx.xxx.xxx.xxx. Enter user name and password. Look for a tab that states software update. Browse for the .bin file you downloaded or extracted from the .zip and click update.
Apr 25, 2009 | NetGear DG834 Router
FIRMWARE
You will not be able to open the file as it is. You have to install the firmware from within the router configuration page. Access the router like 'http://192.168.x.x' and then find where it says firmware upgrade, locate the downloaded file from your PC and then upload it.
Let me know.
Thanks
Dec 23, 2007 | Linksys Wireless-G WRT54G Router
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How to upgrade the firmware on a BEFW11S4
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity (wired and wireless) on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have. Make sure to select the correct router version as well, as firmware upgrades frequently vary by version. You can find your router version underneath your router after the model number. For example, ?BEFW11S4 ver. 2?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
22 people viewed this question
k24674
