Question about Motorola XV1100 (1 Channel) 2-Way Radio
I have the motorola xv1100 vhf i cant hear my other radio unless i hold down the monitor button for open Squelch .they transmit both fine.thanks rob
  • Motorola Master
  • 1,654 Answers
It is likely, the Interference Eliminator Code set differently between the radios. If you can hear after you press the monitor button, this indicates one of the radios has Code shut off (zero), and the other one has it set to a number. Here is a link to the user guide http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf Programming instructions begin on page 32.
Best regards.
Posted on Oct 11, 2010
What does Mon mean on a walkie talkie?
"Mon" is short for "Monitor" and is usually a feature that allows you to momentarily break the squelch (signal filter) and hear anything being transmitted on that frequency. That includes static if there's no transmissions. It allows you to listen for a weak signal that can't break the squelch threshold you have set. Some radios allow you to lock it open by pressing and holding the MON button for a few seconds. Turn the feature off my doing the same thing.
Jul 03, 2014 | Motorola Walkie Talkies 23-mile Range...
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
Motorola mt series not connecting to each other
Activate the "channel monitor" button on one radio while talking on the other and see if you can hear the voice. Then reverse the procedure: talk on the first one while holding the monitor button on the other one. If both radios work with the monitor button held down but will not work without then the CTCSS or CDCSS squelch codes aren't set to the same tone or digital frequency or code. Consult the manual for more information.
Dec 26, 2013 | Motorola Walkie Talkie 2-Way Radio
How to change the squelch on mtx8000
You can always have a radio receive. To transmit require an FCC License, and you need authorization to "Talk" to Public Safety. There are large fines and possible jail time to talk on channels you are not authorized for, especially Public Safety. Sadly, your radio is programmed to monitor only when the button is held down. The frequencies in your area working are a lucky coincidence. Take it to an Authorized Motorola Dealer and pay to have it reprogrammed. Radio is not field programmable. Hold onto your wallet, they are expensive to have programmed. You should have bought a high end digital scanner.
Aug 29, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
Yaesu ftm-10e squelch problem
The FTM-10E is the european version of the dual band amateur radio capable of transmitting in the amateur VHF & UHF (144Mhz & 440Mhz ) bands, that is equal to the FTM-10R sold in the US.
Many repeaters require a predetermined sub-audible tone or signal to be sent when transmitting. If several repeaters in the area operate on the same frequency, they would all transmit at the same time unless they all have different sub-audible tones. These tones allow the user to select which repeater on the same frequency will be used. The tones are either CTCSS or DCS type. CTCSS is "continuous tone coded squelch system" and DCS is "digital coded squelch". CTCSS is expressed as a frequency in Hertz and DCS is a code expressed as a number. CTCSS is more popular, since it has been around longer. When programming or tuning the radio, you will need to provide the repeater's output frequency (and the input frequency if the shift direction and amount isn't programmed - often a 600 hertz shift either up or down depending on isn't already programmed is a default value depending on the repeater output frequency) and whether or not the repeater requires a tone. If it does require a tone (most do), you will need to know the type (CTCSS or DCS) and the value (frequency for CTCSS or code number for DCS) in order for your transmitter to open the repeater and cause it to repeat your transmission AND open the squelch on the radio's receiver so that you can hear replies to your call and other conversations. Repeater directories (both printed and online) will provide all the information needed to access a public repeater, including geographical location, input & output frequencies, squelch type and values to name a few.
If you do not have the correct CTCSS or DCS set, you will see the signal meter on the radio indicate traffic - but you will not hear anything because the radio is squelched. Check the manual page 40 for information on how to program the squelch, and page 42 describes the "shift" I mentioned above. Page 64 & 65 details the theory of squelch via CTCSS and DCS and will help you understand it better.
Basically, you have a "standard" squelch - the knob on the radio and a second squelch that is either CTCSS or DCS. Both types must be set to hear anything. Not having the CTCSS or DCS set will prevent your signal from being repeated by the repeater.
If you have more question, please add them in a comment. I hope this helps & good luck!
Jun 17, 2012 | Yaesu FTM-10R VHF/UHF Mobile Dual-Band...
Will it work with a cb radio
No. CB's operate at the 27 MHz on 22 predetermined frequencies allowed for Citizen Band radios; and your Motorola XV1100 radio is a VHF 150-170 MHz radio with a set amount of built in frequencies to choose from, designed for business use.
Aug 20, 2009 | Motorola XV1100 (1 Channel) 2-Way Radio
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Radio Mic
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them. On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static. The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch. So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it. With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range. Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed. If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem. Take care
Sep 12, 2007 | Garmin Rino 120 2-Way Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Motorola XV1100 (1 Channel) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
