Question about MSI MS-6368 Motherboard
Computer will not boot up i have replaced the proccesor and still will not boot
    Novelist:
  • 112 Answers
This could be almost anything.
I ran into problem possibly similar to this before and the only thing I could remotely contribute it to was a static charge that destroyed the BIOS chip.
Always touch something metal like as water faucet or stove or even the metal PC case or something so you can discharge your body of any static charge you may have. Also whenever possible, wear a static wrist strap.
I would first take the battery out, check to make sure your battery is good. This could also give your problem . If you dont have a volt meter then put your tounge on the battery to tell if its still good enough. You'll feel a little tingle.
Replace the battery and try a boot up again. If it boots up reset the bios settings.
If it still shows the same problem. try unplugging the system then remove absolutely everything from there slots.
All PCI, PCI-E, AGP, Memory , Audio, Everything!
Then start with the necessity's only....
Install a "KNOWN GOOD" video card & memory only. Try that.
If your problem goes away you have bad hardware. Check 1 at a time
If the problem still exists I would say its either the memory or the boards BIOS chip.
If you know someone with a PC that has the same memory, install your memory in their PC or vise-a-verse-a, to see if the memory or board is good. If you find someone to let you try your memory in their PC , DON'T let it complete the Windows start up. You may force their PC to need a reactivation.
Some computer shops also carry a device that checks memory chips.
Good luck 2 u
Posted on Oct 11, 2010
    Brigadier General:
  • 10,406 Answers
> will not boot
When you press the ON button, do the fans start to spin?
Does it boot far-enough to show the "press DEL to enter BIOS SETUP" message?
Does it start to load Windows from your disk-drive, and then "crash" or just "freeze" ?
I have bought new boot disc or restore disc but it runs one cd then blue screen says discs wont work.it tells me to alt ctrl and delete then shows message that ntldr is missing.I know my compaq hp stores...
for setup the bios usually by pressing delete at first screen appear
or for some type motherboard is pressing F2 at first screen appear
after you at setup bios go to boot menu
the go to select boot menu and chose boot from cd for the first boot
then press f10 to save the bios setting and computer will restart
after restart isert your boot disc and if it ask to press any key to boot from cd press any key
then follow the instruction for install the operating system
Mar 04, 2011 | HP Compaq Presario SR5210NX Desktop PC...
My pc turns on...but i get nothing..no video..no
I would try another video card.
If NO posting beep then its either RAM / CPU / MOBO
Dec 30, 2009 | Medion Computers & Internet
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Does the Motherboard Biostar G31-M7 TE work with Pentium 4
Hello there a_guerrero_d.
Here's your GEEK-steer ...
Just so I'm clear, here's what I'm hearing in your question:
  • You already possess an "Intel Pentium 4 proccesor (socket 775)" CPU chip.
  • You are shopping for a motherboard, and have desire to marry that chip with a "Biostar G31-M7 TE" motherboard (MB).
  • That is, until a "dealer" told you "That M/B don't work with these proccesor".
If this is accurate, I believe the one operative word out of all the many above, is "DEALER". My guess is this dealer is "dealing", and either:
  • doesn't want to sell only the MB without whatever chip he currently has installed in it.
  • wants to get you to give up on YOUR chip in order to get one from him,
  • or is honestly mistaken ... because unless he knows something that you, I, and the MB manufacturer are not privy to, he's plainly wrong.
Per the MB's own spec-sheet, the "Biostar G31-M7 TE socket 775 mATX motherboard features an Intel G31 / Intel ICH7 chipset with support for socket 775 ... Pentium 4 Processor"s. I personally would have no hesitation pairing that chip with this MB.
In conclusion, the answer your final question: "Who has the reason". I believe it's clear that it's the "dealer" who has reason ... to not provide you with accurate advice!
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Sep 26, 2009 | Biostar G31-M7 TE Motherboard
Hey i have acer Aspire AS6930-6235 Laptop
Please this Link to check whether your Computer can play this Game or not.
http://www.systemrequirementslab.com/referrer/srtest
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 20, 2009 | Video Game Consoles & Games
My computer isnt turning on
Make sure the BIOS settings are correct for the microproc and also make sure the motherboard supports a dual core processor.
Apr 07, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Proccesor
one only any skt754 cpu will work
Nov 05, 2008 | ASUS K8V-MX Motherboard
How to install windows xp boot cd on acer aspire 4315
When you first start the machine, you need to go into the boot menu and boot from CD drive, or go into bios/utilities set up and set the boot order to boot from CD first. Make sure your XP CD is in the drive, then just follow the prompts.
Jun 20, 2008 | Acer Aspire 4315 Notebook
Proccesor Size
Hi Thunderstar, It's a Socket462. You can see the full spec sheet here. http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=67&CategoryID=1&DetailName=Specification&MenuID=1&LanID=9
Here is the CPU support for this board.
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=67&MenuID=69&LanID=9
If I can be of more service feel free to post your question's here.
Enjoy!
Mike
Mar 26, 2008 | EliteGroup K7VMM Motherboard
Laptop shuts off randomly
Interesting, the new Acer Aspire 5315 from Wal-Mart's Friday sale a week ago exhibits the same problem. I suspect it's a bad temperature sensor diode on the motherboard, or a faulty self-healing fuse. Otherwise, it could be a BIOS defect, where the cooling fan is not running fast enough or often enough to cool the laptop.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
MSI MS-6368 Motherboard Logo
118 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
