Question about Sub-Zero 601R
Sub-zero Fridge not cooling and ice forming
I have an 8 year old Sub-zero (all refrigerator). The unit will not get below 48 degrees and always reads "vacuum condensor". I clean the condensor frequently but message never goes away. When I removed the back panel on the fridge, the top left corner of the coils are frozen in ice. I tried defrosting but iced formed up again. The last repairman that came out simply defrosted the ice and had no real clue on the potential problem. Any help would be appreciated.
  • 3 more comments
  • Crash350 Jun 01, 2008
    can the refrigerant be filled? Is it possible that there is a leak in the refrigerant line and, if so, how would you find the leak?
  • SHAI L Jun 09, 2008
    I have an 10 years old Sub-zero (all refrigerator). The unit will not get below 48 degrees and always reads "vacuum condensor". I clean the condensor frequently but message never goes away.
  • kstall Jun 18, 2008
    Mine is doing the same thing, the condensate inside the back wall, the temperature won't go down, but the compressor won't come on. I've looked at the card and see no hot spots, I've looked at the compressor switch and don't see anything wrong there. All the fans seem to be working normal, the drain hose is not plugged. It's seems like there is a switch that has gilflirted and has everything locked down.
  • James Helmer
    James Helmer May 11, 2010
    Your system may be low on refrigerant. The vacuum condenser is a signal that discharge temperatures from the compressor have exceeded the set point for the warning. that repair man who didn't have a clue, did he check system internal pressures? Frost should form evenly over the entire evaporator and not just at one corner.
  • Mart Hyatt Dec 25, 2012
    I have a Sub Zero model 542 built date jan 1998. It has been having trouble for 5 years and two service calls for the Fidge is not cooling, but the freezer works fine.
  • 56 Answers
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to or call 800-222-7820
Posted on Jan 08, 2009
  • 828 Answers
The leak in the system can be located by a number of methods. First I would look for a slight sign of oil at the point of the leak. 10% of the compressor oil circulates with the refrigerant. Although the refrigerant will leak out as a colorless, odorless gas and be invisible to sight it will leave an oil trace. Electronic leak detectors can detect leaks as small as .5 ounce per year. If the leak is large enough it can be detected with simple soap and water which will form bubbles at the leak point.
Posted on Jun 01, 2008
I have a 12 year old Sub Zero model 624. The ice maker has completely stopped producing ice. And actually, when opening things up we can see ice cubes have formed but they just haven't dumped into the...
This is the procedure but yours seems to be a faulty Icemaker and needs to be replaced since your freezer is cold enough to make ice rapidly.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Jul 27, 2011 | Sub-Zero 642
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Sub-zero 601 fridge won't get below 42 degrees
You both sound like you need a qualified factory repairman out there. If there is a blockk of ice on the back wall you have a low charge in the refrigerant system. It is most likely the evaporator or cooling element as you call it which has a five year parts and labor warranty, then parts only for years 6-12. Here is the link to the factory locator site. or call 800-222-7820.
Nov 24, 2008 | Sub-Zero 601R
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
1,429 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
