Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
I had two partition in my external harddisk...but now it shows only one partition when I plug into my computer. Moreover, the one which is shown also opens up quite slowly...please advise.
    Brigadier General:
  • 10,406 Answers
Connect the WD device
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management (local)
Do you see a "map" of the two partitions on the device?
It's possible that the disk-drive is "dying".
So, make a backup of the files on it, before it's "too late".
Then, if the WD device is still under WARRANTY, exercise the warranty to get a free replacement.
Posted on Oct 11, 2010
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Thanks.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
I have an Iomega MiniMax Hard Drive that was previously formatted for a Mac. It is supposed to be 500gb but when I format it for my PC it only shows about 234gb in the primary partition. How can I regain...
connect your harddisk to computer.
Then right click on my computer icon then click on "Manage"
then click on "Disk Management"
then find your removable device then you find unpartitioned space create new partition .then check.
Also check jumper settings of your harddisk.
It should not be on 16 bit or 32 bit in hardisk.
Jul 16, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
My computer didnt recognize my hard disk
Looks like the controller on the Hard disk has malfunctioned. I am afraid, that the Hard disk has to be sent to an expert nearby for Data Recovery. They would have tools which could be used for getting your data intact. But again it all depends on the level of damage to the Hard disk.You may get all / some of your data ot you may get none. Please consult your hardware vendor for this
Apr 13, 2009 | Western Digital Caviar 40 GB Hard Drive
3 partitions missing on a 250gb SATA hard disk
i think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Jul 09, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Unformatted Space
if you have installed the linux in that space then it will not show some times ...
it will also not if it is not partioned correctly ...
you just go to
control panel >(classic view) >administrative tools >computer management >disk management (this is for windows XP)
see if there is any unpartioned space means then just format there by right clicking on it ....
if there is no unpartioned space then check how many drives you have .....
it will show all the partitions over here if you are not able to see some partition in your my computer then may be that partition may be in unsupported format so it is not showing you ... so delete that partition & reformat you will able to use it ...
if you still persist the problem then you can check the harddisk capacity first & then get on to the things ...
that s all your problem will be solved ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 09, 2008 | Microsoft Windows Vista Ultimate Edition
SAMSUNG SV0411N HDD SHOWN ONLY 7.85 GB
you seem to have a hidden partition Have you used FDISK ? this can be downloaded just do a search You then need to remove all partitions - you seem to have only formatted part of the drive.
Jun 02, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
65 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
