Question about Oreck Cordless Speed JP8100CA Iron
Why does my steam iron spit water while I am using it? I use it with the cord.
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
landsend
  • 1066 Answers
SOURCE: rust from iron
replace the iron as not worth fixing.
Posted on Mar 25, 2009
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: My Rowenta steam iron is
I would try the white vinegar...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Posted on Sep 28, 2010
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
Tip
My Steam Iron is Leaking Water
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
Hi my swan steam gen iron is faulty , when I press the steam button it pours with water from the metal plate part of the iron , any ideas ??? Thanks
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
Feb 27, 2013 | Irons
Water distiller keeps shutting off
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat.and replace if necessary.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Test the heating elements and power for blowing fuse.use the DVOM
God bless you. see the diagram 2_6_2013_8_23_01_pm.jpg2_6_2013_8_23_30_pm.jpg
Feb 06, 2013 | Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron does not spray properly, inspect and clean the nozzle.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Leaking water around base
God bless you
Feb 03, 2013 | Rowenta Irons
How do you test a pump on a tefal steam generater
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
Jan 31, 2013 | Irons
My iron is getting hot but giving no steam can anyone advise
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Tefal easycord gv 5140 no steam
do this. and use the common sense and KEEP the calm. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 24, 2012 | Rowenta Irons
Oreck Cordless Speed JP8100CA Iron Logo
296 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you an Oreck Iron Expert? Answer questions, earn points and help others
