Question about Microsoft Office Professional 2007 Full Version for PC
Excel fromula Hi, I have an excel sheet with a formula for summing columns: =SUMIF(B2:B23,4,C2:C23). This is for my trial 21. My next trial is 33; the following will be 37 and so on. The numbers do not follow any order because the trials in between were just fillers and were deleted. I was thinking of a For-Next Loop. Is there a way to tell the program to look for a nonconsecutive number? Just wondering. Wanted to save some time and effort. Otherwise I have been manually adjusting the formula for each trial. Thank you in advance. And have fun, Adelina
  • Adelina1 Jun 01, 2008
    Thanks. I will try the function you suggested. Will post how I did.
    Thanks again,
    Adelina
Hello, I have copy from internet and paste in excel. but it paste in single cell in this format (A00.9;Cholera). I want A00.9 and Cholera both in different cell.
Could u suggest me how can i do that ? I have used of numbers in this formet.
Regards
Nikky (nikky14003@yahoo.com)
Posted on Jun 25, 2008
    Problem Solver:
  • 15 Answers
You may want to learn the use of function "INDIRECT", so you can construct your formular refer to variables in certain cells.
Posted on Jun 01, 2008
Excel Formula
With data in A1 to C1: A2 =IF(A1>0,1,0) B2 =IF(B1>0,1,0) C2 =IF(C1>0,1,0) A3 =SUM(A2:C2)
Jun 04, 2009 | Microsoft Office Excel 2007
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
Writing a formula for a sumif problem
Brenda,
Your problem is not so much the formula but the cells that contain the hours for each call. Since they contain the text “hrs” (for example “2.25hrs”) this turns the whole cell to text, not numeric, which will always add up to zero in Excel. So do two things:
- Change the cells in column H (Time Spent) to numeric (2.25 instead of 2.25hrs) – you might want to change the column header to Time Spent In Hrs just to b clear
- Use this formula =SUMIF(E8:E26, 1, H8:H26)
For the formula change the middle number to correspond to the operator ID – for example for operator 2 change the formula to =SUMIF(E8:E26, 2, H8:H26)
This should do it.
BTW, sent you a similar email about this.
May 07, 2009 | Microsoft Excel 2007 Home and Student...
Sumif function....
Use the following formula as an array formula, you need to hit "Shift+Ctrl+Enter" after entering the formula. Lets say you have the Name in column "B", the Age in column "C" and the amount paid in column "D". Here is the formula.
=SUM((B2:B7="Abhilash")*(C2:C7>0)*(D2:D7))
It will calculate the amount paid if the name =Abhilash" and the Agr is greater than zero.
Apr 11, 2009 | Microsoft Works 8.0 for PC
Microsoft excel
this is done through formulas. You write them in relationship to one another. Say you put a value into B1 then you write a formula for c2 like =SUM(A1/2)which means the sum of A1 divided by 2. or you can say make a formula that is like this =SUM(A1/C1) which means the value of A1 divided by the value of C1.
Jan 10, 2009 | Computers & Internet
Excel formula
You can do that using the formula CONCATENATE, solving your report.
in C2 you could write: =CONCATENATE(A2,B2)
in C3 you could write: =CONCATENATE(A3,B3)
in C4 you could write: =CONCATENATE(A4,B4)
in C5 you could write: =CONCATENATE(A5,B5)
Nov 24, 2008 | Microsoft Office 2003 Basic Edition...
BASIC EXCEL FORMULA
Are you looking to solve any particular problem?--- because there are a huge number of possible formulas in Excel.
However, in my opinion, the most commonly needed ones are addition, subtraction, division, multiplication, and summing.
Suppose you have the following numbers typed into your Excel spreadsheet:
columns: A B C D
rows
1 20 3
2 10 4
3 15 2
4 1 2 3
Then suppose you type in the following formulas (in the D column):
columns: A B C D
rows
1 20 3 =A1+B1
2 10 4 =A2-B2
3 15 2 =A3*B2
4 1 2 3 =sum(A4:C4)
Then the following answers will appear in the D column:
columns: A B C D
rows
1 20 3 23
2 10 4 6
3 15 2 30
4 1 2 3 6
Sep 29, 2008 | Microsoft Computers & Internet
Sumproduct or conditional sumif with multiple criteria in vba code...
i'll just reply to your conditional sumif query.
yes, you can do multiple criteria query but with a matrix formula. you may look it up. nonetheless, here is how one would look like:
{=sum(if(range1=A x range2=B x range3=C, sum range))} note that x (multiplication) is used to denote intersection of the criteria
initially, you'll enter it as:
then, edit the cell (F2) and press ctrl+shift+enter for the brackets { } to appear.
Jun 27, 2008 | Microsoft Excel for PC
SUMIF formula
One in general should not use Find & Replace.
I would recommend always creating the first formula manually by selecting the cells. This will avoid common errors like extra spaces.
May 11, 2008 | Microsoft Excel for PC
Formular to show number and cell references
The formula for A1 is: =SUM(B4,B5)
A2 is: =SUM(C4,C5)
A3 is: =SUM(A1:A2)
To test this, put 25 in cell B4, 25 in cell B5, then 30 in cell C4, and 30 in cell C5.....the result in cell A3 is 110.
Hope this helps.
Mar 07, 2008 | Microsoft Excel for PC
Microsoft Office Professional 2007 Full Version for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
