Question about Bosch 1656 8 1/4" Circular Saw W/ 60 Bevel
Just bought a used 81/4" saw. Needs a power cord and sounds like the bearings are rattling a little. I'm pretty sure I can change the power cord, but don't know if changing bearings is a "do it yourself" job. Advice?
  • 30 Answers
Many people chose to service their own tools. Not knowing your skill level the best advice I can give you it to look at the exploded view of the tool on www.boschtoolsservice.com. and decide if that is something you can tackle, If so you can order the parts right from that website. If you do not feel comfortable, there is nothing wrong with taking the tool to a Bosch Authorized Service Facility. The last thing you want to do if your not comfortable is risk doing more damage to the tool and being out the money you paid for the tool and parts. Before you log on make sure you note the product # of your machine because there are 2 (0601656039 or 0601656139) this will make sure you get the right parts.
Hopefully this solution helps you, if so please rate me. Thanks
Posted on Oct 11, 2010
Bosch 71/4 wormdrive keeps flipping breaker
If the saw is tripping breakers, either you are trying to run the saw on a circuit that can't handle the amps the saw needs to run or something is wrong with the saw that is making it draw more amps than it should.
Power supply: You should be on a 15 amp circuit or higher for this saw. Popping breakers can also be caused by using long or low guage extension cords or a low guage power cord on the saw. The saw should have a 14 guage power cord on it and extension cords should not be lower than 12 guage if 50 feet long.
Saw: You've already replaced the cord & switch, if the brushes are OK, look to the mechanics of the saw. The blade should turn freely and smoothly by hand with the saw unplugged. Things to look for are a lack of lubrication in the transmission, binding or broken gears in the trans and binding or seized bearings on the armature or worm gear set. Also, a dull blade forced through wood will also cause the saw to be overworked and draw enough power to trip breakers.
Feb 18, 2013 | Bosch 7 - 1/4" Skilsaw Circular Saw
My 10 in. Craftsman table saw is blowing the house circuit breaker
If it was the bearings you would probably hear a change in the sound of the saw before a significant amount of drag would cause this problem. If you are using the same outlet and the same cords as when you did not have this problem, then something has deteriorated. Is the blade sharp? Has the cord become compromised - either the wire itself or the plug? (The stranded wire in the cord could be hanging on by a few remaining strands.) Does the plug fit nice and tight in the outlet? Perhaps the motor has overheated and has partially shorted out some of the windings. On the other hand, if you have changed extension cords, perhaps the cord is too light or long.
Jul 09, 2012 | Craftsman 10" Table Saw
What lubricant to use on a mk wet saw
I know that graphite works pretty well in wet situations but may not stay on as long. Any type of silicone spray should work and should not wear off as fast. In the past I have used good ole bearing graease, like you would use in marine applications. It should stay on long but just a little messy if you don't have easy access to the bearing. I had an MK wet saw myself and used marine grade bearing grease. You just have to get a large tube for just a little grease is the only problem.
May 06, 2012 | Mk Diamond Saws
Chain saw frozen, removed cord starter the engine wont budge even with a large screwdriver in the cooling vanes, a poulan
some one ran it with out oil pull spark plug spray in some wd-40 let sit for a few days then try again if it dosent move its scrape
Feb 15, 2011 | Homelite Garden
Skilsaw is 2 months old. sounds like the bearings are shot already. has an odd klunking sound
even its just a 2 mos.old if your power tool was over used there is the tendency to sound like krunkling sound.,particularly when the unit you bought is just an imitation.
now,if the skilsaw you have now is let me say genuine,not overused and you are not comfortable with the sound you hear from it,then there is the posibility that it has a factory defect.Now,becoz it is already unto you,you can open and check the bearings,and also the "half moon" between the power gear and the axle/rod of the armature,it might be loosen.If your skilsaw is genuine and branded,you can buy it for areplacement of the said bearings & half moon.
you can check the brush too,becoz when it was over used the brushes are surely shortened and not equally grined..and if that so,an uncomfortable sound or noise will hear from it.
Nov 06, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
KS850 circular saw 'burning' & smoking
The brushes in the electric motor have failed..
And sounds like bearing are shot too..
The motor is shot..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 | Saws
Horid noise! Is it the bearings?
It sounds like a bearing alright, I'm pretty sure you can replace the bearing, but you will have to slip the belt off the pulley and remove the trunion, (the part that raises and lowers the saw blade), put this on you work bench and remove the blade shaft this should allow you to pull the bearing or pound it out of the bearing retainer. I would do this ASAP before you ruin the shaft.
Feb 28, 2009 | Craftsman 10" Table Saw
My PSU model ATX-1956d is sick! Any natural remedies out there?
Hey Vrob,
Power supply fans rattle and vibrate when the fan bearing is worn out. They rattle even louder and harder when cool or cold, and quieten a little after warming up and expanding. I would get it out and seek a new one like it. From what you are saying, the computer is not a brand name, so it's probably a clown using standard power supply. take it out to the computer shop; they'll get you a new one. Fans can be changed but fan out is fan old is the rule.
Good luck
Feb 18, 2008 | HP Bestec ATX-1956D 200w HP Part No...
Mavica FD-88 Rattles
you have nothing to worry about. It's normal. The 3.5 diskette drive is a 4X speed and the noise you hear is normal. All FD83's and 88's will make noise and vibrate a little.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Bosch 1656 8 1/4" Circular Saw W/ 60 Bevel Logo
245 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
