Question about Euro-Pro Vacuums
I have a European Delux extra-wide ironing table with built in sleeve board and delux cord holder Model EP49. I need a replacement cover and after calling the 800 number listed am told it is no longer in service. Where can I get a replacement cover?
This is for Euro-Pro Model # EP49.
I have just ordered this same ironing board cover by contacting Euro-pro headquarters.
The # is 1-800-361-4639.
It is shipped from Montreal.
Posted on Nov 30, 2010
How to get into Hayden super pack delux vac unit
Are you speaking about the Power Nozzle? If so, you need to remove the head light cap. It has clips on each side. Using a small flat head screwdriver gently pry the light cover off from the sides.
Now you will see two screws. Remove those screws. Now you need to pull out on the sides of the cover while hinging it from back to front.
That is it. There is the motor, belt and electronics.
To reassemble, just revers the steps.
May 23, 2014 | Hayden Industries Vacuums
Replace dome light bulb in 2004 f150 truck
Your dome light has three different bulbs inside of it. Two of the bulbs are reading lights which is part number 912. The bulb mounted in the center is part number 578. LED versions are available but are still pricy. They would cost around $75.00 verses the $10.00 it would cost to buy the other style. Good luck.
Jan 15, 2014 | Reliable C8SBH Sleeve Board and Bottle...
I am working on a u5290-900 hover vacuum ,when operating dust leaks out under dirt cup cover. i put a piece of card board on top of cover so extra presure would be applied to the top of cover. this seams...
Dear Sir:
Will be better idea to replace the cup cover. The pice of card will not function for a long time.
Proceed before another extra problem coming.
God bless you
May 24, 2012 | Hoover U5290-900 Upright Vacuum
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Jul 11, 2011 | Vacuums
How do I get the u5290-900 apart far enough to remove old power cord and plug in a new one?
First you need to remove the Dirt Cup followed by the front cover / handle. Page 4 1-6 of the PDF Manual below shows how to do this.
http://static.fixya.com/Manuals/H/Hoover/5288_900_prg_B4F5E4DE0DB02590E2525C367EFB5C4C.pdf
This should then give you access to remove the internal cover and replace your cable.
Jun 26, 2011 | Hoover U5290-900 Upright Vacuum
I have a Dirt Devil easy Steamer delux,but lost the owners Manual,forgot how to use it ,can you help ?
I believe the following manual is for your machine. It's model # MCE6600. It's what comes up when a search is done for Easy Steamer Deluxe.
http://www.dirtdevil.com/manuals/?id=c6f182b2-b418-447d-951f-ca9456153b3d
Jan 10, 2011 | Vacuums
I have a Euro Pro Compact Performer model # EP 171 which I love. It is the best iron I have found for my quilting class. When I went to use it, I found my cats had chewed the cord to the point that it is...
HI. All appliances has warranty on it. Default would be 1 year warranty. If your device is within the one year warranty. you can have it repaired by your manufacturer withut a charge. If device is alraedy out of warranty. you can still have it repaired but you will cover for the damaged part that need to be replaced or repaired in your device. Check the store where you purchased the unit. Maybe they can do something about it.
Jul 01, 2010 | Euro-Pro Vacuums
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace the cord. There is a short near the housing.
hi may i suggest ? if you wish to renew the complete cord/wire? why not fit a longer length to facilitate more reach thro different rooms from the preferred wall socket ? the problem of short /breakage of wires within outer sleeve near casing is common on lots of vacs it is not a difficult job to replace if you are competant with wire and colour codes remove the access cover where wire enters vac then observe the attachment of each wire ? then disconnect faulty cable transfer the rubber tube that is normally fitted at entry point to vac at this point to new cable remove outer sleeve of new cable same length as old cable to reveal the inner wires then connect to vac sockets resecure cable to vac as previous dont forget the rubber tube? refit entry cover and fit a new 3 pin plug bs kite marked ? then away to vac the rooms? hope this helps
Oct 20, 2008 | Hoover Vacuums
Vacuums Logo
1,251 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
