Question about Garden
Hi ya quick update on this tiller ISEKI AC 40 very hard to start & when it does runs for about 10 sec's then stops re-try to start again very hard runs for about 10 sec's again same over & over. Checked & double checked carb Mikuni, cleaned with cleaner & blow line float seams ok jets cleaned fuel shuts off when gently closing float screw1-1/2 out, fuel system all cleaned all filters etc no air leaks inlet/exh/cyl head etc, good blue sparks however s.plug still appears a bit wet when removed after trying to start so could this be the coil breaking down under load, thanks very much for your time taking getting a bit lost now any idea's
2 Suggested Answers
  • 150 Answers
SOURCE: Hi ya got a old ish tiller in for repair, it is a
From your description we will assume it is flooding. If you suspect float problem, check float level, holding the carb upside down the float should be parallel to carb body when needle seat is closed. On metal floats this is accomplished by bending the tab that rides on the needle, units with plastic floats you may have to replace it. Also remove float and shake it, should not be any gas in the float, this will make it flood. Also set carb adjustment screw at 1.5 turns out, may need a little tweek from there.
Posted on Oct 05, 2010
Why does my ignition switch 40 amp maxifuse keep blowing?
get in an accredited auto electrician as there is a dead short to blow a 40 amp fuse
may be what the mechanic did is the problem but I think that it would have blown immediately if it was
I would be looking for a wire heavy size wire like to the alternator, or after the fuse box etc that is touching ground or a relay that is faulty
Jul 12, 2016 | Pontiac Cars & Trucks
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this,...
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
May 16, 2014 | Honda 25cc 4-cycle Mini Tiller
I used my tiller one time and the second time I used it, it was hard to start and when she did, she blew white smoke and would not start after that.
This happens frequently after a tiller, mower, snowblower, etc. sits for a season. Your tiller is probably flooded due to a stuck carb float. You can try a quick fix by tapping gently a few times on the float bowl, then pulling the spark plug and cleaning it with a wire brush, and then wiping it dry with a cloth. If you have a new spare plug to install, that is even better.
Try to start your tiller again, and if the same thing happens, your float is still stuck and you may need to have your carb serviced.
You can try one more alternative if you do not want to go through the bother and cost of having your carb serviced (or purchasing a kit and trying to do it yourself), but it is a 50/50 "hit or miss" sometimes it works, sometimes it don't type thing:
Drain all the gas out of your tiller. put about 2 ounces of carb/injector cleaner in the tank, and top off with gas. Give the float bowl a few taps. Now, pull the spark plug..... make sure the spark plug wire is at least 1 inch away from any metal. With the throttle set to full and the spark plug removed, Pull the starter cord 5 or 6 times (if you have electric start, crank it for about 5 seconds). You may see some vapors come out through the spark plug hole- this is OK.
Clean, install, and connect your spark plug (again, a new plug is even better). Give the bowl a few taps for luck, and try and start your tiller again. If the procedure worked, your tiller may run rough for 10 or 15 seconds (maybe even up to a minute or so... let it take its course!), but then smooth out.... if it stalls, don't worry.... Start it back up.
This will often work for tillers, snowblowers, mowers, generators.... pretty much any 4 stroke "lawnmower engine". It all depends on how badly the float is stuck after the engine sits.
You can minimize having this problem in the future (it may still happen, but less often and less severe) by adding a good fuel stabilizer (such as the brand name STA-BIL) to your gas and running for 10 minutes or so before you store your "lawnmower engine" for the season.
If you still have problems, the likely cause is a stuck carb float and the carb will need to be serviced.... but hopes are high that my solution helps!
Good Luck, and Thank You for using FixYa!
Apr 20, 2011 | Garden
Hi ya got a old ish tiller in for repair, it is a ISEKI AC40 problem is hard to start & when it starts it will only run for about 10 seconds, so far checked plug which has a good spark, compression ok,...
Oct 05, 2010 | Garden
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
LG Window Air Conditioner
Check the repair shop for warranty on the work before you do anything else.
May 03, 2009 | LG Heating & Cooling
LG Window AC Problem
send it back again!
Humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
Nov 25, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
