Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon PIXMA MP600 printer - paper feed
I have used the printer for about 6 months now with no problems. However lately whenever the paper feeder starts to feed in a sheet of paper, the paper skews in one direction and thus jams. It acts as though the roller is pulling on only one side.
I appreciate any help you can offer.
Ralph Locher
  • Paul Blum Jun 12, 2008
    I too am having the same problem with the same printer.
    Problem Solver:
  • 6 Answers
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> Canon PIXMA MP600 printer - paper feed - mp500_asf_led.gifaper source.
ASF
TheCanon PIXMA MP600 printer - paper feed - mp_500_cassette_feed_switch_led.jpgP500
Cassette
The above illustration shows a PIXMA MP500
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Posted on Jun 12, 2008
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Always have code 5700
5700 is a sheet feeder error, the feeder in the back where you put fresh paper. What I find most often is something has fallen in the paper slot stopping the paper from feeding. Sometimes ink pens, money, paper clips, nails, candy, and even jewelry. You can turn the printer over and shake it, or look inside with a flashlight and small mirror. Last time was a sheet rock screw. If you find nothing, it's probably a shop repair to look inside.
Feb 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
When I try to print only one side of the paper is pulled down
Probably you have a object which blocks paper from left side on feeder.Look carefully using flashlight in the feeder.If you don't see anything the printer must be disassembled.
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Pixma ip1600
the gears in the paper feeder tray are getting blocked somewhere or are worn out please try to clean the gears.they are exactly below the feeder.white in colour.and r not very small you can easily locate they r on the right side with printers front facing towards you.please check the gears and make it clear.
Oct 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600
1. use better qulity of papers
2. either clean sencer of printer
Feb 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 paper jam
I recently had the same problem and was very bummed, because I like the printer, having received it as part of an Apple bundle promotion.
The problem I was having is that I had paper in the rear (auto sheet feeder) area and when I'd try to print, all I heard was clicking and then I'd get a message that there was no paper installed.
Here's what to do.
On the panel, on the left side, there's a button called "Feed Switch."
You'll notice that there's a graphic of the printer to the left of the button with 2 lights. Push the Feed Switch button to toggle the light from the front tray (cassette) to the rear tray (auto sheet feeder)... and when the light is on the rear try (vs. the front tray) you're all set.
This will fix the problem.
Jan 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper feed problem
Sound like something foreign is in paper path
Dec 24, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
5,286 people viewed this question
old marine
old marine
