Question about Refrigerators
Refigerater warm the freezer works great but the fridge is warm u can hear ice crunching when push on the inside of freezer. if u copletely thaw freezer and turn back on it works good 4 a few weeks if ur lucky
  • 828 Answers
You have a malfunction in the auto defrost circuit. Could be a timer, heater(s) or defrost thermostat. Defrosting it manually is only a temporary fix. Under normal conditions the system will auto defrost at least twice every 24 hours.
Posted on May 31, 2008
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
FFB6187
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Bosch FD8709 Fridge Freezer (American Style) Freezer section not cooling (Ice maker has stopped making cubes and food starting to thaw) Fridge section seems to be working OK..! In Manual says that the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Bosch Freezers
Two months ao, my wife and I bought a new 28.5 cu. ft. double door fridge/bottom freezer. My food is defrosting, both fridge and freezer, and the ice maker ice cubes were melting. I set the fridge temp to...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 13, 2011 | Samsung Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
