Cannot conect to BTHomehub2-CSH4 - Computers & Internet
  • 4,281 Answers
For that make sure all settings on BT homehub are perfect. Access it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 11, 2010
Cannot conec to btHomeHub2-CSH4 pc is hp .home windows vista
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
Click Here
Oct 11, 2010 | Nintendo Wii Console
How do I access the internet using a BT home hub set up for wireless operation, without having to go through BTfon
Hi Graham
This should be fairly straight forward.
Your BT Home hub should be transmitting 2 signals. One called BTfon and another called something like BTHomeHub2-PGD3.
The second is what your computer should be connecting to to access the internet. If you look at the back of your home hub you will see 4 rows of numbers/text.
One should say SSID and have have the same ending as the transmitter that your computer should be seeing. Underneath that it should say WEP code or WPA. (or something similar) What follows is the password you need to enter to access that home hub's internet transmitter. The BTfon thing is for the telephone that comes with some versions of the hub - it's not for the computer.
Jun 13, 2010 | Computers & Internet
I have no sound on my hitachi 61swx12b
Howdy;
Try these items first: re-set TV and any type of BOX you have hooked to the TV. 2) Ensure all cables are secure. 3) Make sure that there is not a speaker switch on back of TV. 4) go into customer menu (audio) and make that speakers are turned on. 5)
Symptom: AUDIO MUTE OR HUM.
Cause: Remove ALL jumpers on bottom of SRS pwb.Add 1000mf@16v across CSH1 add 1000mf@16 across CSH4 add gnd wire 24ga from PSU1 conn pin 18 to IT02 pin 97.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 61SWX12B 61" Rear Projection...
Can I use my acer aspire one wirless with bthomehub2. I can connect with cable
Not sure of what your issue is,you can connect to the internet by cable/DSL but not to your home wireless network?,or another wireless network? either way most wireless networks ask for a user code or password.Does the network appear with an open lock symbol or locked.Even if it's your network you have to grant access.Good Luck.
Sep 07, 2009 | Acer Aspire One A150-1006 Notebook
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Ps3 can only connect to one or two games online playing fifa09
I'm not sure about 3659 but these are the ports I have forwarded
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
Also DMZ would be perfectly fine as long as long as you set a static IP on your PS3
What DMZ allows is that any ports communicating to a specific IP access, so if this IP is alway connected to your PS3 no harm to other computers or devices can be done!
Dec 02, 2008 | Sony Playstation 3 (PS3) Console
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
