Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Freezer works fine but the refigerator does not get cool
  • 4,066 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Oct 11, 2010
Maanita
  • 1142 Answers
SOURCE: Frige not cooling
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Mar 24, 2009
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
fridgetech
  • 473 Answers
SOURCE: Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Posted on Oct 21, 2007
TheMobilian
  • 8220 Answers
SOURCE: refigerator / freezer not cooling properly
You have a bad defrost heater.
READ THIS PWEASE
Posted on Jan 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
Posted on May 18, 2009
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
My Fisher and Paykel upper refigerator is not working. The lower freezer seems fine. Wha can be done to fix?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 20, 2010 | Fisher and Paykel E522BLXU
I have a Kitchenaid KSCS20QFAL01 refrigerator. The freezer side gets cold but the refigerator side does not. The difuser has been replaced but did not solve the problem. It was working fine until the...
clean all the dust off the coils on the back of the fridge and all the dust out from underneath the fridge. This was the cause of my fridge not cooling and it worked and cost me to have somebody come out to blow all the dust out from underneath. Give it a try
Jul 24, 2010 | KitchenAid Refrigerators
Freeze slite cool but refigerator is not cool at all
Sounds like a defrost system failure. This could be the freezer fan, heater, timer. You need an OHM meter.
You can manually defrost the freezer with a hair dryer that will get it working for a couple of days. Remember there is a lot of ice behind the freezer back wall, you can only see the tip of the iceburg.
Jan 23, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator will not cool
also the complete mod number would help
May 21, 2008 | Refrigerators
Refigerator and Freezer not cooling
You might try cleaning all the dust if any from the back or access to the bottom front.
Feb 14, 2008 | KitchenAid Superba KSCS23IN Side by Side...
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
96 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
