Question about Loewe Televison & Video
I cannot connect my ps3 slim 250g to my Loewe tv, I have connected the cables from the ps3 to the tele but it still doesn't show up on the screen, I have looked through all the channels but I still can't connect it, please help
    Problem Solver:
  • 12 Answers
This is simply a software issue. Your software is not compatible with their software, in other words, If after switching from TV to Aux 1, Aux2, Aux3, Etc. it still doesn't work, it never will.
Posted on Oct 11, 2010
Loewe tv power
Hi, the original remote that comes with your tv is the correct remote for you. because you have it connected to the sonos-playbar you will now need to use the Sonos remote to control the volume. The Loewe remote will not work for the volume anymore. Sorry.
Oct 18, 2013 | Logitech Televison & Video
The ps3 is on and working but will not show anything on the tv
that sounds like a connection problem. check all the wires to make sure they're connected properly. if that doesn't work, then you need to change the settings on the console itself. ie. if you're using an HDMI cable to connect to the tv for example, that option needs to be selected in the play station settings... the problem is that you cannot see what's on the screen.. is there anything else you can connect the ps3 too? or can u use the cable that came with it to connect it t the tv?
Aug 19, 2011 | Sony Playstation 3 (PS3) Console
Have a PS3 slim, when i turn it on at connect it to the TV with the Component cables, everything works fine, picture shows and the sound comes out just fine, but when i try to connect it with the HDMI...
You need to turn on the tv and set to HDMI, Then power on the PS3 and hold down the on (standby) button until it beeps again twice and it will pick up the TV and display on the HDMI,
If this doesnt work go to system settings and video settings and set the output to HDMI.
Anthony
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
NEED HELP HOOKING MY PS3 COLOR STREAM CABLES I HAVE MONSTER HD CABLELS
If the ps3 is connected and it doesn't show on the tv, unplug both the tv and the ps3. then plug them both in and turn on the tv first then the ps3 by holding the power button of the ps3 for about 10 seconds before it beeps then it should show up on the tv screen.
May 16, 2011 | Toshiba 46UL605U LCD TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Im trying to get my ps3 to connect with another tv
turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
make sure a hdmi cable is not connected at back of ps3.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Laptop to samsung tele
  1. Ensure that the connection is a direct cable connection from the PC to the TV, no converters or cable adapters as these are generally not Bi-directional which is required for a PC to see a TV.
  2. Try turning on the TV, then booting the computer. Some devices require the initialization signal from the computer to activate the port on the TV.
  3. See if the TV input select has an option to search for active signals.
IF none of that helps, post the exact model of TV and computer as well as the type of cable connection you are using.
The biggest stopper most of the time is a cable converter.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
376 people viewed this question
Top Loewe Televison & Video Experts
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
