Hoover maxi 6 tv30 tumble dryer wiring diagram
2 wires have come off one of the components in my my dryer when i replaced the belt. Where can i find the wiring diagram?
4 Suggested Answers
  • 234 Answers
SOURCE: Hoover TV30 tumble dryer belt gone..how do I
On models that do not have disengageing clips for the top to be removed, you must remove the front (face panel) and this is usually done by 2 small screws at the bottom of the front panel. Then you tilt the front out and will be able to unhook the front from the top. Now, you need to undo a small bolt or screw inside between the top and the side panel (there is one on each side). Goodluck, Macgivor
Posted on Jan 02, 2010
  • 3 Answers
SOURCE: Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Posted on May 26, 2010
emissionwiz
  • 79077 Answers
SOURCE: I have a hoover maxi 6 tv30 sorry the serial
most dryers regardless of the make and model use the same basic procedure to replace the belt, while u are in there make sure the drum rollers are in good shape. go to the link below instructions with pictures
http://www.diyprojectsonline.com/projects/interior/fix_dryer_belt.php
Posted on Sep 26, 2010
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Whirlpool Clothes Dryer AWZ 121
It sounds like it is the belt. When the dryer heats up the belt expands a little and when it gets wore out, the tensioner doesn't have enough spring to keep it tight. It might work a little when it's cold before the belt expands.
This belt should work for your dryer but verify the length.
http://www.amazon.com/Whirlpool-341241-Dryer-Drum-Belt/dp/B00DM8J15C/ref=sr_1_fkmr0_2?ie=UTF8&qid=1395071968&sr=8-2-fkmr0&keywords=whirlpool+awz121+belt
Here is a helpful Youtube video on how to do the repair.
http://www.youtube.com/watch?v=GzYmoS9brMY
Here is a link to the Service Manual
http://elektrotanya.com/whirlpool_awz121.pdf/download.html
The bottom of this link shows some typical ways a belt runs past a tension wheel and links for your dryer. If you replace yours I would recommend taking a couple pictures before removing the old one so you can refer to them when installing the new one.
http://www.repairclinic.com/Dryer-Belt-Diagrams
Mar 17, 2014 | Dishwashers
My hoover maxi 6 reverse air tumble drier has no hot air when drying. the filter care light is on. what does this mean?
The thermal overload has failed. Replace the heater assembly on the rear of the drier, under the metal cover.
Jan 27, 2010 | Hoover Dryers
Hoover TV30 tumble dryer belt gone..how do I access the belt area? I cannot slide the top off!
Jan 02, 2010 | Hoover Dryers
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Jan 18, 2008 | Dryers
Televison & Video Logo
431 people viewed this question
Top Televison & Video Experts
