Question about Kenmore Elite HE4 Electric Dryer
Dreaded F24 Error Code
I've read all the blog on this problem but could not find the temperature sensor anyway on my washer. I called for service but they can't come till next week. Please help if you can and advice me what this problem is. No water comes out at all into the washer. Water only in the soap dispensier.
  • maryannlhy May 31, 2008
    My washer and dryer is brand new. This is the first time I am using it and I encounted this problem.
    Kenmore HE5T Steam Washer
    Model No: 110 47789 700
    Serial No: CSU 3214404
  • Kenmore Master
  • 19,396 Answers
I will try to find a diagram, so that you can replace the sensor
Posted on May 31, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
F24 error code
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23F to 217F[-5C to 103C]) during the water-heating step
of the WASH cycle.
NOTE: To find correct Ohm reading refer to the Water Temperature Sensor section.
1. Unplug washer or disconnect power.
2. Check the water temperature sensor and connection to it.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Refer to the Water Temperature Sensor section.
Oct 19, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
What is F-24 error code
The error code means a problem with the heat sensor.
Failure
Code
Condition
Check/Repair
F24
If the water temperature sensor (NTC) value is out of range (23°F to 217°F[-5°C to 103°C]) during the water-heating step
of the WASH cycle.
Thanks,
E-ware
Jul 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Had the washer on express wash the error went f24 move selector to whites and seems to be working.what do you think might be the problem? Thank you Duncan
Hi
Error F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This error appears when temperature sensor fails. It could also appear due to a failed electronic control or due to a wiring failure. Unplug the washer and remove the service panel, check the resistance of temperature sensor using a volt/ohm meter. Take out the screws at the bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, remove the wires off of the temperature sensor at the bottom front of the washer tub. Temperature sensor should give reading of about 10K ohms (10,000 ohms) of resistance (RX10 or RX1) at room temperature. If the resistance reading of sensor is fine then it is due to a wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
The meaning of error code 24?
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Sep 13, 2010 | Kenmore HE2 Plus Front Load Washer
I have a code f24 on display screen the I have to hit stop start over, what is f24?
The F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is usually caused by a failed temperature sensor (Key 24 in the image below). A wiring failure or a failed electronic control board could also cause this fault code.If you are able to unplug the washer and safely remove the bottom front service panel, then you can check the resistance of this temperature sensor using a volt/ohm meter. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. A reading that is more than 30% off would verify a failure in this component. Replacing the temperature sensor would fix this type of problem.
If the resistance reading of the temperature sensor is okay at room temperature, you could have a wiring failure or a bad control board. There is also a slight possibility that you could still have a bad temperature sensor even though it measures okay at room temperature. A technician would normally be needed to check for this type of failure.
Feb 24, 2010 | Kenmore HE2 Plus Front Load Washer
HE2-plus washer will not start. error, status light shows "F-24"
code F24
sorry but the following information is for TECHNITION SERVICE(only)
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
"Was this helpful?"
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Fault F24 on kenmore front load washer
Apr 20, 2008 | Washing Machines
Error code F24
I see the same problem and now that I know it's a water temp sensor, I really don't have a problem. Living in Houston it get's so hot the cold water is hot coming through the pipes. I didn't have this error 24 until summer...
Nov 18, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
97 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
