Question about Gateway Computers & Internet
I have a gateway 9510 server running windows 2003. The system alert light is orange, and the two tops fans are blowing wide open making it very, very loud. It will boot up properly, I just want to make the alert light go away and make the fans run at a normal speed.
  • witonweb Oct 11, 2010
    Thanks for responding. I tried cleaning the fans but they still run at a high rpm speed. Just noticed the lights on the them do not come on either.
  • 99 Answers
Solution for your problem is remove the fan and clean the dust accumalated on the wings, this would solve your problem. Even then if your problem is not solved do replace the fan with new one.
Regards
Rudra
Posted on Oct 11, 2010
Dell insipirion 530s power light stays orange fan running wild
Hi deb lewis,
the orange power light is your warning that your power supply is going bad. I'd replace the power supply with the same size or larger (preferred)
Best of Luck
Mark
May 11, 2012 | Dell (E210882) Motherboard
System Fault indicator light on in a Gateway 975 Rackmount Server
If it is on steady and green, the server is operating normally.
If it is on steady and orange, the server is "in a critical or unrecoverable condition"
This is according ro the manual located at http://support.gateway.com/s/Manuals/Servers/8510289.pdf
If it is orange, for further diagnostics, you should see POST error codes, or hear relevant audible beep-code patterns, which can be interpreted by checking the tables in the PDF Server manual linked above. (Pages 125 and 128 respectively.)
If it's green, of course, you dont have a problem.
Feb 19, 2010 | Gateway 975 Rackmount (gtwy975) Server
Windows server 2003 routing
i would say use your server as dhcp or set your pcs with a default gateway that is your server.
Dec 28, 2009 | Microsoft Windows Server 2003 Enterprise...
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Fan problems: We have Xseries 236 . When running with windows 2003 server the fans are running on high speed. The ambient temperature is about 25 degrees celcius (70 degrees Fahrenheit). The LEDs on the...
Since more then one fan is going crazy after 5 minutes, try these things first:
Make sure the server has enough space where air can ventilate properly. Also make sure there is no dust or dirt sitting on top of the fans cause lack of air ventilation can make the fans start acting up. Also make sure the room is staying nice and cool so that way cool air is being ventilated thru the server.
If you have done these things and your server is still acting up then your motherboard is starting to go bad cause that means the motherboard is having trouble regulating the voltages going thru it and thats why the fans are running really crazy the way they do.
If its just one fan I would say replace the one fan but since both are acting up, I doubt that both fans would go bad at the same time.
Aug 11, 2009 | IBM eServer xSeries 236
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Computers & Internet Logo
293 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
