Question about Directed Electronics 479V Remote Gen 2 Responder
Car shut down , will no start, or reconize remote keypad
  • 20 Answers
Check your antenna, should be mounted on the windshield. unplug it for a couple of minutes and then plug it back in, then check the remote. make sure the alarm has power, try putting the alarm in valet mode, if it goes into valet with no problem then the alarm is fine, then you can re-program the remote. if it doesn't go into valet then the problem may be the alarm and not the remote. hope that helps, dave
Posted on Oct 11, 2010
2003 Honda Recon 250 Wont Start
backfiring is a timing or valve issue .
Sep 01, 2016 | Honda 2007 FourTrax Recon Base
SECURITY PROBLEM CAR WON'T START OR WAIT 3 MINUTES TO START ON 97 DEVILLE
Bad key switch.The computer does't reconize your key so it is shutting down the injectors so it can't be stolen. The switch housing should be replaced to.
Apr 19, 2011 | Cadillac DeVille Cars & Trucks
I have a chamberlain opener Model 3280. I have tried to set my three button and keypad model 976LM remotes from my old house using the learn button, but it just won't learn the remotes. I have tried...
For your hand remotes try this:
Press and hold the button down on the remote while you press and immediately release the learn button.
For the keypad:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
If this doesn't work your logic board is bad.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
The projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
How do I code the garage door wireless key pad?
simple ;find the smart button on the opener and pressit ,their will be an indicater light next to the smart button that will remain lit ,then go over to the keypad and put your 4 digit code in example1234 then press enter on keypad and hold down for 3 seconds until garage door opener lightbulbs shut down and come back on , and thats it simple as pie! when the lights go on and off on your machine it,s telling you that it has received the code that you just programmed into it , guaranteed to work everytime , Thank you for letting me help you Sincerely Glenn mayer
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whisper Drive not working
Why not call Liftmaster on 800 number. I can see a problem going down with safety beams, but not up.
Jan 13, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Liftmaster garage opener model #114OLM
when you are programming , how long do you push LEARN button for, If you push for 6 or more seconds, you are wiping out all code, Push for 1 second to add a remote or keypad,
Jan 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Directed Electronics 479V Remote  Gen 2 Responder Logo
274 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
