Question about Horizon Fitness HTM0597-00 T92 Treadmill
My Horizon model T500 treadmill is shutting down in the middle of my workout losing all power. I have had it for approximately 3 years and I have never had any problems. It just started doing this in the last week. also the tag on the front of the treadmill listing all of the information does not list the serial number this section is blank
2 Suggested Answers
  • 20 Answers
SOURCE: My Horizon T101 treadmill has
no there isn't, in fact the key is a magnet plate mechanism but you should try attacking the problem by first checking the fuse which is located at the head end of the machine. If that doesn't work then remove the motor cover and get a qualified electrician/technician to check the circuit board for any possible faults.
hope this helps
Posted on Apr 09, 2011
I have a Horizon Treadmill, Model T101 with ERROR Message 5101 MI 09. What does this mean? How do I fix it?
Hi there.... this may be a problem with the upper console CPU timing or associated parts. You can contact jatinahATrocketmailDOTcom for repair on these stalled consoles. Good Luck!
Oct 19, 2016 | Horizon Exercise & Fitness
The belt won't start on my treadmill. the speed is already at 0.5 when you turn it on instead of zero. everything starts going and speed can be increased but belt doesn't move......
Hi there, I think I can help. Now depending on model year the Horizon T500 can use a couple different motor control boards, most all of which are fixed at jatinah electronics which you can find with a Google search. It sounds like a failed control board fixed for 99 or less and exchanges available with returned cores. Good luck
Feb 04, 2015 | Horizon T500 Treadmill Walking Belt
Treadmill shuts off and won't run
Check that the speed sensor is the right distance from the magnet on the drive wheel. If it does not pick up a signal whithin one or two revolutions it will shut down.
Feb 11, 2014 | Horizon T70 Motor Control Board
My horizon ct5.1 turns displays select workout, buttons all beep but do not respond
replace the old batteries with a new ones, type hybrid rayovac, with the same polarity. clean the contacts batteries with c. cleaner
2) Tight the ribbon cable inside the display board.
3) Adjust the REED swithc, see the diagram attached. Test for open or faulty. Clean it, tight the connector very well.
God bless you
Jan 09, 2013 | Horizon Exercise & Fitness
Horizon digital DT850 treadmill turns on can select workout hit start button belt does not turn on/rotate
Step 1:
seee the video attached and lube the rollers bearing too. Happy NEW yEAR .God bless you
Step 2:
Test the input voltage motor, if there are the motor need repair see my personal TIPS for motor help. see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Dec 31, 2012 | Exercise & Fitness
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
My Proform crossover Elliptical's interface keeps shutting off in the middle of the workout. Any ideas?
Dear Sir:
Electronics in consoles can fail at any point like a light bulb. We have spikes in the power supply to our homes which can wear out components over time. If the machine shutting off is there are indication some components in the power supplies is faulty. Test and replace.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 05, 2012 | Exercise & Fitness
Why is p1 flashing on my t500 treadmill
Please see your owner manual , page 18-19 you will see the Workout p1+p2+p3 etc Code for your treadmill Horizon.
If you do not have the owner manual please download:
www.horizonfitness.com, go to service customer then parts&manuals give you model, etc, and download for free.
sincerely.
Mery Christmas.
ernesto cuadra
Dec 11, 2011 | Exercise & Fitness
Treadmill just stops in the middle of a workout.
Probably is getting overheated.... Also, I have seen some models that stop the workout when the belt is getting too worn out.... Perhaps you should look into replacing the belt. If the screen is losing power too, then it is definitely power failure (in which case, you should examine all the cords and connections.
Feb 28, 2011 | Proform Exercise & Fitness
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
Horizon Fitness HTM0597-00 T92 Treadmill Logo
136 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
