Question about Vestax PDX-2000MKII PRO Turntable
Where is the fuse located in the turntable - Vestax PDX-2000MKII PRO Turntable
Wwhich fuse do use for ion turntable
Your vacuum cleaner is 13 amps, so your turntable is 3 amps. There are two glass fuse sizes, so take fuse to Radio Shack - it could be a metric 5mm x 20mm or a 1/4" x 1-1/4" glass fuse. Regards.
Aug 04, 2014 | ION Audio TTUSB05 Turntable
Turntable not moving
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. If the fuse is blown, the oven would be "dead". Either repair is rather simple with parts available online.
Nov 11, 2017 | GE Microwave Ovens
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Apr 01, 2014 | Technics SL-1200M3D Turntable
Power source
Sounds like your power transformer went out, or you blew the fuse - located on the rear of the turntable, next to the power supply and RCA connectors - not all TTX's have this fuse.
If it's the transformer, is not an easy fix, and requires professional help.
Good luck.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Jun 19, 2008 | Numark TTX1 Turntable
They wont turn on
Check the fuses. If the fuses are good, then it's the transformer that is shot. The fuses are located underneath the turntable platter. If your unit does not have any fuses, then the only problem could be with your transformer. You can PURCHASE A REPLACEMENT TRANSFORMER HERE.
Good Luck!
- Davis.
DIGITAL ANALOG THERAPY
Jun 05, 2008 | Technics SL-1210 Turntable
Power failure
First check to see if your turntable has fuses installed on the main PC board, which is located underneath the turntable platter. They should be easily visible once you remove the black protective cover underneath your turntable platter. Check them out first to see if they are blown, if so, replace with equal rating fuses. If you don't see any fuses, or the fuses look fine, then your power transformer has gone out - this is the grey metal box looking thing next to your PC board. This would need to be replaced. Parts for this model can be purchased HERE - just pick your turntable, and that's it!
- DJ PRO LAB
Feb 29, 2008 | Technics SL-1200MK2 Turntable
Powere input
Some ST-150's have fuses, some do not. It would be on the rear of the unit, next to the power cable. If it is not there, then it might be under the turntable platter, on the main board. Not sure if you have a US or non-US model. So check both places. If you cannot find the fuse, then you don't have one. It's not that hard to locate. If this is the case, then your power transformer probably fried and will need to be replaced. This part runs about US$40
- DJ PRO AUDIO
Nov 18, 2007 | Stanton STR8-100 Turntable
Fuse
The fuse is located on the rear of the unit. Remove it and take it to an electronics shop for replacement. If it does not work, then you've fried the transformer and will need to have it replaced by a qualified technician.
Sep 17, 2007 | Stanton STR8-50 Turntable
Blown Fuse
The fuses for this model are located underneath the turntable platter. You can replace this yourself, however, please be sure to disconnect the unit from it's power source before proceeding. You will have to remove the metal turntable platter, exposing a black protective cover. Remove the cover, and you'll see the main PC Board. There are 2 fuses on the lower left side. Pull the fuses and take them to your local electronics store, or order online @ www.1200s.com. IF your unit does NOT have any fuses, then your transformer is damaged, and will need to be replaced by a qualified technician. Also, the fuses are only meant to circumvent small changes in electrical current. Many times, these voltage surges, will fry the fuses and the transformer. So if after you replace the fuses, it still doesn't power up, you will need to also have the transformer replaced. Good Luck!
Sep 14, 2007 | Technics SL-1200MK5 Turntable
Vestax PDX-2000MKII PRO Turntable Logo
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
