Memory upgrade Is it possible for me to upgrade the memory on my Acer L320
  • rojer Jun 02, 2008
    I appreciate the L320 has two slots and it can be upgraded from 1 to 2Gb.
    Its the physical problem of getting to the memory slots. I've been in, but there is no access to these slots!!
    What I really need is the proceedure of installing more memory. The L320 is extremely tightly packed - there is no room for access to anything. Once inside, the next module has a handle provided for removal ...BUT... what is the next step in removing it?
    It appears that once that has been achieved I'll be able to see the mother board and hopefully the memory slots and do the job.
    Novelist:
  • 111 Answers
The other expert's solution here gives you the information and practical steps you need to know about what to do to change the memory in a computer.
here is some additional background information you should know specifically about the Acer Aspire L320. this pc is a small form factor (sff) pc. as is common with sff computers the Acer Aspire L320 is based on laptop/notebook rather than desktop pc technology.
unscrewing the single large central silver cross-head screw at the back of the pc means the right hand side panel is free to slide out. slide backwards and lift up to remove the side panel. sliding this panel out will break the green Acer warranty seal on the right hand side of the pc so make sure your warranty has expired before going ahead and breaking this seal.
once it is open inside you will also see three small black plastic clips which hold the front plastic panel of the pc to the case. gently lever each of the three clips upwards and forwards with your thumbnail to release the front plastic panel. disconnect cable connecting the front panel to the inside of the pc (the front panel cable connector near the usually yellow Complimentary Metal Oxide Semiconductor (CMOS) or Real Time Clock (RTC) battery in the front top corner of the pc is easier to disconnect and reconnect than the one on the panel itself). thread the loose cable through the oval slot in the metal frame near the top of the front of the pc case. put the disconnected front panel to one side.
you will also see a silver panel with a black plastic handle in the center. this panel is connected to the hard disk drive cradle that contains the hard disk drive underneath. you will also see towards the center of the inside of the pc about one inch from the back of the pc a small black cross-head screw that fixes the black handled silver panel to the rest of the pc.
use a magnetic screwdriver so you don't lose the screw when you unscrew it. removing this screw means you can now partly lift the silver panel with the black handle and the attached hdd out of the pc case. using your thumb and index finger loosen and disconnect the hdd power and data cables near the back of the inside of the pc. put the silver panel and hdd to one side.
now you will be able to see the two ram slots at the center near front of the pc. you will see laptop/notebook type spring loaded ram memory slots. disconnect the other ends of the hdd power and data cables makes access to the ram slots easier. release the two catches on the side of each ram module to release it and it will spring up so you can slide it out. as you correctly say there are 2 memory slots and the maximum memory each slot can take is 1gb. our pc usually comes with two 512mb ram modules. you can either replace one original ram module with a new 1gb module to upgrade from overall ram from 1gb to 1.5gb or remove and replace both to upgrade to 2gb. the memory type for this pc is a PC5300 DDR2 SODIMM RAM MEMORY MODULE.
to install new memory slot the new memory module in at the correct angle and then push it down until it clicks in place by the two side catches clicking into the semi-circular notches on the edges of each memory module.
after upgrading the ram reverse the above steps to reconnect the internal cables reinstall the hdd and silver panel and reattach and reconnect the front plastic panel.
before closing the case, reconnect all the rear cables and test that the pc starts properly and if the new memory you just installed shows up in Windows Vista Home Premium which is what this model of pc usually comes with. if so, shut the pc down and disconnect all the rear cables again before closing the case up reconnecting the cables and starting the pc again.
in Windows Vista - 'computer' - 'system properties' shows you the installed memory.
between the other expert's answer and this one you now hopefully have everything you need to know about changing memory in an Acer Aspire L320.
Posted on Nov 05, 2011
    Problem Solver:
  • 13 Answers
There are 2 memory slots in Acer L320. You can use program called cpuz to check how many memory modules are you using, and what size are they.
If you have any module free you should be capable to upgrade memory.
Posted on May 31, 2008
Acer aspire 5100 series bl51 video memory upgrade What is posible here?
This is a laptop. The video chip is on the motherboard. This machine cannot have a video card added.
Jul 26, 2014 | Acer Computers & Internet
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire l320 non booting
did this work OK in the past and just recently fail? Or are you just now attempting to get it to work for the first time, please claify and it will be easier to assist you, but double check your memory installation in either case.
Feb 08, 2010 | Computers & Internet
I have an acer L320 that has decided no to start up anymore all I get is the blue light comes on,says acer then no signal.Not the monitor, how can I retrieve my data when it doesn't even startup or...
see that is probably a ram memory issue...and the thing to do is to remove ram memory ...blow to clean the slots..take it carefully not to touch it cause of magnetic reasons...after that remove the Bios battery to try to make it see the Ram again ....if it does not boot at all..this means that is not seeing the ram memory...
Nov 04, 2009 | Office Equipment & Supplies
MY acer aspire L320 Aspire wont even turn on! everything is connected its been ugraded to 2GB RAM and but thats the onlything thats not standard on it.. any thoughts?
take out one stick of memory and see if came on if still same result take out the modem ( last pci slop on the board ) if still dont came on try new power supply thanks
Oct 25, 2009 | Acer Computers & Internet
HOW DO I install new memory in acer aspire L320
First step would be to lookup your system specs either in your manual or at the Acer website. See what RAM is compatible with your system. Once this is done purchase what you need. Open the case and you should see the RAM modules & slots. If you are replacing RAM you will need to remove the old first. If you are adding to empty slots just line it up properly and seat it in the open slots. Close the case and reboot. System should automatically recognize the new specs. Make sure you disconnect power and properly ground yourself before touching anything inside your case. Hope this helps.
Oct 16, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Acer aspire L320 wont boot up can hear drive running I'm fixing this L320 for someone and it also has the same problems as above, i've took the system apart, changed the memory, put the hdd into my own...
When you say wont boot is it getting and video ouput at all? I'll assume its not. Check all your connections. One time i didnt have a SATA cable fully seated, it was just at the slightest angle creating a short and freaking the whole computer out (it was my dvd drive too!). Check all the cables and ram is fully seated as well as the CPU. Only try to boot with one ram stick at a time, possible dead ram stick too. IF its a cheapy motherboard best to just replace it.
Jun 03, 2009 | Acer Computers & Internet
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Removing RAM from Acer L320
look at this link:http://www.crucial.com/store/listparts.aspx?model=Aspire%20L320
or go to crucial.com and use the memory scanner,its terrific!hope it helps!
Oct 30, 2008 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
