Question about TruTech PLV1615T 15 in. LCD Television
Will not pickup local hd channels - TruTech PLV1615T 15 in. LCD Television
    Sergeant:
    Champion:
  • 431 Answers
Any antenna will work make sure you hook up in back for dtv and not analog,older lcd still have analog then do a scan trough the menu just for dtv
Posted on Oct 12, 2010
    Problem Solver:
  • 12 Answers
In order to p/u local channels, you need an external antenna.
Just like the kind grandpa had on the top of his house,,,,
The tru-Tech is a low cost / low feature tv and may not have the required circuits to convert antenna broadcast signals to a video / audio signal.
Posted on Oct 11, 2010
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Dec 03, 2009 | Sharp Televison & Video
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
Hitachi 53FDX20B -- HD tuner?
hi, hd ready means the tv is capable of re-producing the hd picture from a cable or satellite co. call your local cable/sat people they can advise you which channels are which in your area, video-tek
Jun 06, 2009 | Hitachi 53FDX01B 53" Rear Projection...
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
Get HD Signals but it Says Channels not available
you might have to look for "hidden" hd channels.
most cable companies are broadcasting the local stations unencrypted, so you should be able to receive them and sometimes a few other "basic" hd channels like discovery or tnt.
try googling your cable system, city and hd channels to see if someone has posted a list of channels (eg, 88-1 or 102-1)
Jan 12, 2008 | Panasonic TH-50PX75U Plasma HDTV
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Pixelation on Local HD Channels Only with or without cablecard
This is caused by one thing, poor signal strength.
Mar 01, 2017 | Televison & Video
TruTech PLV1615T 15 in. LCD Television Logo
131 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
