Question about Frigidaire GLGR331A Gas Dryer
Glgr331ao heats for 5 minutes or more than doesnt heat after that i hear it coming on, igniting.i cleaned the duct out and inside of the unit.i cant check the flame because when you take the front panel off ,to get at the stuff in front the drum rides on the panel .
  • Frigidaire Master
  • 8,220 Answers
If you hear the click then the ignitor is working. It would not click otherwise.
The flame sensor is also working because you hear the click. The solenoids are known to get hot and quit with age. Replace them
glgr331ao  heats for 5 minutes or more than doesnt - 1_13_2012_8_14_36_pm.jpg
Dryer repair
Posted on Jan 13, 2012
Ihave an olsen high effiency gas furnace it cycles fine it heats fine but when the blower kicks in i can hear rattle type noise through the ductwork but at the furnace location i cant hear the noise
You need to gain access to the ducting and make sure that a joint hasn't come apart or rodents haven't gained access to the ducting. Also, if the duct is square metal ducting with the insulation on the inside, a piece and come loose. The trick is trying to find it. You can rent a plumbing camera and run it through the duct as well.
Jan 22, 2017 | Heating & Cooling
Heating system doesnt work
First make sure the fuse and relay for the fan motor are good.If they are then with the ignition and the heater fan switch turned on wiggle on the connection going to the blower motor resistor also check connector for burn marks or melting.The location of the resistor is on the passenger side down towards the floor in the heat duct usally there is to screws that hold it in place.It should be the only thing that has wires on it coming out of the heat duct.
Jan 14, 2012 | 2006 Jeep Grand Cherokee
BURNER WILL NOT LITE AFTER THE INITIAL HEAT CYCLE,THE IGNITER COMES ON BUT NO GAS COMES THRU. ALL IHEAR IS A CHATTERING SOUND COMING FROM THE BURNER AREA. THIS IS A KENMORE GAS DRYER, SER.# LGR762OLGO
if the igniter glows do u see the flame, and then shuts off,
you can have a copule things going there
one you might a block exhaust vent,full of lint, even when it seems like the duct is clear all the way to the outside, you might have some lint inside the unit, try cleaning it by removing the back panel screews, the air duct, and then remove i thinks is 4 or 5 screws from the air shoot, open it an clean the inside, what sometimes happens is that the blockage is there on the duct, the heat is created but won't exit the unit, and it back flows, rising the temp, and the dryer won't turn back on till it cools off
if you clean the ducts an you still have the problem, then i would look at 2 thigs first the coils replace em
an then the gas valve....
goosd luck post some feed back thanks!
Feb 01, 2010 | Kenmore Dryers
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Kenmore gas dryer heats for several minutes ,then goes cold
I'm haveing the same problem with my frididaire gas dryer. I replaced the ignitor and cleaned the inside parts with a vacume and still having similar problems as yours. I think I will replace the temp. sensor that is attached to the flame tube inside the dryer next. To gain access to the inside parts you will need a putty knife to release the top panel. Just slide the putty knife along the top seam in front of the drryer. There are 2 clips that realease the top peice. With the top lifed up you will see 2 phillips head screws attaching the front panel to the dryer. Remove those screws and lift upwards and the front panel will lift right off the unit.carefully place the front panel to the side without damageing any wires attached. Then all your gas assembly parts will be visable in the bottom left cornner of the unit.
hope this helps,
Aug 23, 2009 | Kenmore Dryers
I have a Dometic rooftop air conditioner 8000 model. When on heat in cold climate I found the a/c unit did not heat our caravan sufficiently.
the reason for this is either the reverser valve or air restriction first clean the a/c by removeing the cover on the roof and the inside clean the cooling fins then remove the sheet metal or plastic cover over the intake fan & clean the shroud then clean the filters inside the van reassemble every thing then turn the unit on & from inside check the side were the wires are to feel for air by turning the unit on cool there should be a big diffrance between the intake from the out put use duct tape to seal off the sides also clean the duct work with air to remove blockage in the duct
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Ignitor problem?
if you remove the 2 screws on the right and left bottom plate and open the door and youll see 2 screws that panel will come off turn the oven on and you should see 2 burners on both sides and they should ignite.if they do and go right out you could have 2 problems.when the burners light they hit a probe called a flame sense.this probe plugs into a heat board and if the board doesnt sense the flame you will get a red no ignition light.clean the probes that sit right on the burners with sandpaper and see what happens,if that doesnt work if the unit has pilots clean the pilot orfice and if that doesnt work the heat board may be bad.how old is the unit?
Feb 25, 2007 | Vulcan VC44GD Gas Double Oven
Frigidaire GLGR331A Gas Dryer Logo
59 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
