Question about Toshiba Computers & Internet
At start up, screen does not get psat the Toshiba screen
    Genius:
  • 1,456 Answers
Hello
This radical resetting of the computer is called a system recovery (not a system restore) This will put your computer back to factory settings but you will lose any files on your Hard Drive like pictures, music and word documents.
THIS IS HOW IT WORKS :Some older computers and ALL Toshiba laptops come with a system restore disk. Simply place the disk in the CD tray and hit ENTER, if that does not work, power the computer off and on with the disk in the tray, wait for the special system recovery screen to appear, (be patient)
If you were not issued with a disk, then the following is for you.
Each computer manufacturer has a special key you have to hit WHEN YOU POWER ON the computer.
Toshiba laptop is F12
Here is the trick- power the computer off, and then power it back on and start tapping the F12 key until a screen pops up saying "DO YOU WANT TO DO A SYSTEM RESTORE" OR "WELCOME TO SYSTEM RECOVERY MANAGER" Once you see something appear on the screen, stop tapping and just follow the instructions. Some of the older computers may ask you for the restore disks so have those ready. Most newer computers do not need restore discs. The whole system restore could take 2 or 3 hours. When done, reboot your computer and it should be all new and speedy again.
Posted on Oct 11, 2010
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
Toshiba blank screen
Sounds like a corrupted OS install. Could be caused by a number of things like: virus, failing Hard Drive, system lost power while doing an update, etc. Very hard to diagnose such a problem without being in front of it.
Sep 15, 2012 | Toshiba Computers & Internet
Whenever I try to start my Toshiba Satellite Laptop the Toshiba logo comes on but then the screen goes blank and all there is is a blinking underscore in the upper corner of the screen; I already set
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
Log10 Psat = A + B/T + C log10 T + DT = E ( (F-T)/T) log10 (F-T) A = 4.325629 E+1 B = -4.293056 E+3 C = -1.306883 E+1 D = 4.231114 E-3 E = 2.342564 E-1 F = 6.770000E+2
Hi
Log is a statement of current conditions
Psat is saturated pressure
T is temperature
DT is temperature difference
Regards
Gordon
Apr 20, 2011 | Heating & Cooling
Please can you urgently tell me how to start my computer in safemode it is a techra M5
Restart the computer, then when you see the toshiba screen, start tapping that f8 key. It should give you a screen to choose modes. If that doesn't work, only press it once during or after the toshiba screen.
Please rate if this helps!
Mar 03, 2011 | Toshiba Tecra M5-S4332 Notebook Pc
G4 mac boots but no icons or anything else
ask for genuine microsoft software delete
Sep 15, 2009 | Apple Computers & Internet
I have a Toshiba 300. When I start up I get a black screen.
on the black screen, hit the ctrl, alt and del keys all at the same time, choose the applications tab, then click on the new task button. in the box type "explorer.exe" without the "
Mar 10, 2009 | Toshiba Satellite Pro L300 Notebook
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Computers & Internet Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
