Question about Canon PowerShot SX100 IS Digital Camera
Memory card will not stay in and latched. Is there a simple solution or does this require a professional repair?
  • j_stratton_h Oct 11, 2010
    For $50 it would be worth it to have it repaired professionally. However, I can't seem to find a Canon repair facility that will touch it for less than $99.00. Where did you get your $50 repair estimate?
    Quick response, but solution requires professional repair.
  • 11,896 Answers
There is a little clip inside the camera that is supposed to move to grab and hold of the card. The spring can wear or fall out or get bent and no longer hold the card in place. The camera will have to be disassembled carefully so you can gain access to the memory card slot. Then the card bay will have to be examined to see the position of the spring and latch. If it's bent it will have to be straightened out. If missing, a new one will need to be replaced with a steady pair of hands. Canon will repair it for $50 plus shipping. Fixing it yourself is not the easiest task but can be done with lots of patience and concentration. The hard part is finding a replacement spring and latch if that is the case.
Posted on Oct 11, 2010
  • Nate Stansfield
    Nate Stansfield Oct 11, 2010
    Ship it directly to canon themselves.
My microwave door wont stay close , how do i fix ?
Hey Abraham Acevedo, thank you for the post!
From my understanding the door on your Frigidaire microwave, PLMV168, is not staying closed. You could be seeing an issue with either your door latch or latch assembly within the microwave. Since these components require patience and precision to replace or remove from your appliance, I always suggest seeking professional assistance. One must be very careful handling these replacement parts as they can lead to potential harm. -Matt
Jul 30, 2014 | Frigidaire PLMV168 Microwave Oven
Recover lost data
Take out the memory card of your JVC Everio HDD Camcorder.Put it into a card reader and connect it with your computer.Then download a third party data recovery software to recover data from memory card.I have succeed to recover videos from SD card with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data.
Anyway,download a trial version and scan your memory card for free to preview whether your lost ata can be recovered. http://www.any-data-recovery.com/product/index.htm
Oct 28, 2010 | JVC Everio GZ-MG365 HDD Camcorder
When I try to insert a memory stick into my sony cyber-shot dsc-p20 it won't lock in place and I can't close the door. Help!
Try quickly pushing the card in and letting it go, fast. Keep trying this and see if the card finally locks, you could have a build up of fluff on the latching mechanism. doing this could free the fluff and problem solved.
Its also possible that the latching mechanism has dislodged which means a dismantle at a repair shop.
Apr 10, 2010 | Sony Cyber-Shot DSC-P20 Digital Camera
My memory card will not stay in. shoots back out
Make sure that you have the right orientation.
you may have to push a little harder since it is spring loaded. it needs to be pushed deeply in order to be latched in.
Mar 01, 2010 | Samsung Propel A767 Cell Phone
Memory card wont stay in my phone. whenever i push my memory card into the slot it just comes back up
Perhaps it has a latch mechanism - you have to push it a bit deeper inside, and then it will latch into place. To remove, push it again deeper and it will pop out.
If it's not the case, perhaps your socket is a bit worn out, and/or the card is thinner then usual - you can try to increase the friction by applying some self-stick paper or tape on top of your card to make it a little bit thicker.
Dec 03, 2009 | SanDisk 2GB microSD Memory Card
Canon EOS 400D dslr will not work various CF memory cards. Error message ( replace CF card)
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
Apr 02, 2009 | Canon EOS 400D Digital Camera
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I bought a 1GB memory card for my son's Acer T180 that matches the memory card requirements, but it does not fit. What am I doing wrong?
Be very careful when handling memory. Don't touch the gold contacts. Put the old and new memory beside each other, contacs to contacts, but not touching. Are the notches the same, are there the same number of contacts, is the length the same? When putting memory in, the latches must be all the way open, and the memory perfectly centered and aligned in the slot, no time for poor vision. The notch is not in the middle, the memory only goes one way. Then push the memory down until the latches click in on their own.
Aug 18, 2008 | Acer Computers & Internet
SD card won't stay in camera
Quick fix... Roll a little piece of paper up or fold into a small square the set it on top of the memory card and tape that down. so that it puts pressure on the card and keeps it seated in the slot. It sounds like the spring inside the camera is broken. which you will need to have sent out to be repaired unless you have a local camera repair person. And that is going to take about a month. Actually more... unless you find a local repair person. Because Sony bought out minolta a couple years ago and shut down all the minolta repair centers and got rid of almost all their parts. I once had a customer who sent in a minolta to get it fixed and it took about 8 months to get it back. Because of parts.
So You will probably want buy a new camera. but there are still a lot of those Minolta's around on clearance and you can get a great price.
Hope that helps,
Caleb
Jun 26, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Memory card wiped clean!
The only time I have had this happen, is when the cicuit card inside slid back.  This keep it from connecting to the PS2 memory slot. It is simple to repair, open the memory card up and slide it forward infront of the stay that supposed to keep it forward.  If the stay is broken, then put someting inside the memory card  to keep the circuit card pushed forward.
Oct 14, 2007 | Sony PlayStation 2 (PS2) Console
Canon PowerShot SX100 IS Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
