Question about Sony Audio Players & Recorders
I have a Sony STR-AV770 Amplilfier. The left channel does not work at low volume but begnis working when I turn it up. Any suggestions?
    Genius:
  • 1,456 Answers
Hello
The amplifier may have been panned to the right,this will make sound produced by the speaker to sound mostly on the right and you will hear little or no sound on the left.Turn the panning knob to the middle,this will make the volume of sound coming from both left and right equal.
Sony amps have a protection mode that can trigger these. Turn the volume down; never set the amp's volume control to the maximum anyway as it can damage the amp. Turn off the surround sound if both the A and B speakers are powered at the same time; check that the speaker wiring is intact. Turn off the amp, wait awhile and turn it back on again.
Posted on Oct 11, 2010
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
When i turn the volume up from my sony receiver strda3400es de protection comes in. By lower volumes it works ok.
Hello
Measure load resistance. That is the output connected resistance. If it is too low than normal this type of protection will be activated. Measure the impedence [resistance] of speakers connected to the output. It must be more than 4 ohms/channel effectively. OK.
May 17, 2011 | Sony STR-DA3400ES Receiver
I have a Sony STR-AV770 receiver that has stopped its output of volume to the left side. Any chance of me fixing this on my own?
your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
Mar 20, 2011 | Sony Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Sony STR-DE597 6.1 Channels
Repair time ...circuit board to front channel has a fuse prob or capacitor
May 24, 2008 | Sony STR-DE597 Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
