Question about Maytag MSD2456G Side by Side Refrigerator
Maytag Side By Side Problem
We have a Maytag Ref. Model # ends in 2756DE. Large side by side. We started having problems with the ice machine and after numerous costly attempts to repair gave up. We have an ice machine so we abandoned the one in the ref. Then we still kept getting glacier ice build up in the freezer so we disconnected the water source entirely. We till keep getting water on the kitchen floor (it's ruining our hardwoods). I though it was coming from the freezer but sometimes it look like it is coming from bottom of the right hand side of the refridg. side and running under and coming out on the freezer side. This has been going one for at least 8 months. Can you help?
  • 828 Answers
Check and make sure the drain pan under the refrigerator is in position and the drain hose is in the pan. If it misses the pan it will put water on the floor.
Posted on Jun 01, 2008
I have a ksra25ilss01 model side by side kitchenaid ref that will not stop making ice. It keeps overflowing the door tray.
The wire in the ice machine part is being heald down by ice I would guess, try and mess with it empty it all out of ice and let it start over again.
Jun 24, 2011 | KitchenAid KSRA25ILSS Side by Side...
Ice maker not working. water supply goood. makes loud noise on and off . Maytag Ref. model MZD2665HEB
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gf342
Jul 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice Maker
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Jul 07, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
No Ice Dispensing
can be ice maker or water valve
your ref has a double valve
Apr 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker dispenser
i own a similar model for 2 years now and have had no problems with it. maytag is better than kenmore sad to say
Jan 13, 2008 | Maytag MFI2568AE Side by Side French Door...
Maytag MSD2456G Side by Side Refrigerator Logo
319 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
