Question about Xerox Office Equipment & Supplies
Screen displays "PU K ASIC ERROR" message. Printer doesn't respond and I also notice that the paper trays are not initiated.
atlasuk2007
  • 85 Answers
SOURCE: Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Posted on Aug 28, 2007
  • 13 Answers
SOURCE: load tray message
Paper size is incorrect (your software needs Letter not A4). Try to change format in a program that you are trying to print from.
Posted on Nov 30, 2007
SOURCE: Error message: load paper face down in main tray
Here is a reply from HP about this error. The "Semifull Reset" seems to work for me so far.
Tony H.
I am Munik from HP Total care for All-in-One products and this is my response to you in regards to the query related to HP Photosmart C5180 All-in-One. Thank you for contacting HP Total Care and its a great pleasure for me to assist you.
I understand from your e-mail that your printer makes a lot of noise when it tries to print and also gives the following error message "Out of Paper Load paper face down in Main Tray", I regret for the inconvenience and apologize for the same.
To isolate the issue, I recomemnd you to refer this website and ensure the correct paper load:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00704348
Copy the URL from "http" to "c00704348", paste it in the address bar of the browser and then press Enter.
And now to resolve the issue, I request you to perform the following website:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00786157
Copy the URL from "http" to "c00786157", paste it in the address bar of the browser and then press Enter.
Now check the status, if the issue persist then perform teh following steps:
I. Power cycle
Follow the steps below to power cycle your all-in-one:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
II. Semifull Reset:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
I believe the above information helps you. If the issue persists, please get back to us with the results. We will be glad to assist you.
We appreciate you giving us the opportunity to provide you with superior customer service. I wish to take this opportunity to thank you for being one of our most valuable customers.
Have a nice time.
Sincerely,
Munik
HP Total Care.
Posted on Jan 30, 2008
  • 13 Answers
SOURCE: The paper tray has paper
MP - is the manual tray on the side. Sometime I've had trouble with switch that locates the paper on the side. Joggling the paper has helped me.
Posted on Oct 26, 2008
Corysf62
  • 188 Answers
SOURCE: Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Posted on Nov 22, 2008
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Aug 28, 2007 | Dell 3100cn Laser Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Lexmark C510 34 short paper error
The error means that the printer has determined that length of paper in source specified on second line of display is too short to print formatted data. If this error occurs again, press Go to clear message.Ensure paper size setting in paper menu is correct for paper size.
Dec 04, 2012 | Lexmark C510 Laser Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Cannon mp530 says load paper when paper is loaded
    Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
    • Make sure that your paper is properly inserted.
    • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
    • Be sure that there are no damaged paper in the tray.
    • Clean the rollers using a cotton buds and a clean water.
    • Now try printing again.
    Hope my solution will help. Thanks for using fixya.
    Jul 08, 2011 | Canon Office Equipment & Supplies
    Microsoft Word
    there is no paper in your printer tray , pls insert paper . if the problem does not solve then reinstall printer
    May 04, 2009 | HP LaserJet 1320 Printer
    Error message on 4050n printer "manually feed hp tough letter"
    What error message is on the display?
    To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
    Jan 20, 2009 | HP LaserJet 4050n Printer
    ROS Trouble with Xerox DouPrint N17
    The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
    Dec 09, 2008 | Xerox DocuPrint N17 Laser Printer
    251 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
