Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Can you get just the color wheel for the 939P977A20 Light engine, or do you have to replace the entire thing?
Lost the color red
theres a digital module that comes with the light engine..but your gonna spend some dough..probably only available with a complete light engine replacement..sry
Jan 08, 2014 | Vivitek V37655 56" DLP TV
Wd52525 yellowish color when static. Menu has some pixelation. Colors are off.
It does not matter---these sets are so bad (this one) they sell the entire chassis or the light engine which has the color wheel in it and last time I looked the wheel does not come unless you buy the engine.
May 24, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Phillips rear projector color wheel
If you need the wheel Google the model number with "color wheel" and note some of these Philips sets the wheel is not available by itself--must purchase entire Optical Light engine.
Apr 12, 2012 | Televison & Video
I have a samsung hlp6163wx/xaa I replaced ballast and bulb. Color wheel sounds good but just a dark blue picture and perfect sound what could it be?
Some things to be aware of here--if the color wheel turns too slow set will shut down---if you hear a fan like or high pitched sound it is the wheel.
If a uniform blue and dark it is likely the DMD which is the box the wheel connects into and can be purchased by itself (forget that as for about 50 more than it costs you can buy the entire light engine that comes with it)
Bottom line: Likely a bad or damaged optical light engine.
A photo posted here or somewhere else with a URL location might tell me more.
further questions? Press the make a comment button on this page.
Mar 25, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a 46hm95 tv. red light flashes 3 times, then pauses indicating color wheel problem. is this a dealer replace part or can i replace? if so, where is listing to buy part? is it worth fixing or...
Reports indicate the color wheel is sealed in the light engine and MAY NOT BE AVAILABLE AS A SEPARATE PART.
You can contact either Andrews Electronics (LA and largest OEM parts dealer in USA---some of these sets do not sell it as a part--have to buy the entire light engine which is more than the set is worth as a used set.
Google the model number with color wheel after it and you will see what I am talking about.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Toshiba 46HM95 46" HDTV
Little green and white boxes on the screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Found it right here http://www.discount-merchant.com/MITSUBISHI-RMD62-939P977A20-Light-Engine-p/1138084.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP5674 color wheel problem
yes, but you will discover it is about 450 and a bit difficult to replace and position correctly---the entire engine with it is 500/550.
Aug 23, 2009 | Televison & Video
Replaced color wheel
OK, THIS TV HAS BEEN A DOG,IT seems the light engine was going bad to start with so it is a good thing i diidnt replace :LAMP,or Balster,New Color wheel is working,But with BAD Light Engine Lamp will not longer come on either!
Jun 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Display is to high on dlp set
the entire light engine assembly is not positioned in far enough. did you replace the color wheel yourself ?. if not call the tv repairman back to reposition
Apr 12, 2009 | Samsung HL-S5086W 50" HDTV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
