Question about Canon Cameras
Camera has been idle for a couple of years. Tried to start it and charge it. Not a glimmer from it. Bought a new battery, still no response. Does not show any life when on the charger and the battery removed. Charger does get warm after a couple of hours connected. Any thing else I can do.
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 31, 2008
I cant get any response from my Intova IC12. This worked when I used it last year? When I try and charge the battery - nothing. No power. What should I do?
Hello mayairwin,
If you didn't use the camera/charge the battery for a year, then the battery may be dead. Li-ion batteries cannot be left to fully discharge. They must always have a slight charge in order to be recharged. Please contact us at Intova for customer service by email, fatema@intova.net or call us at 808-837-0074. Thanks
Feb 02, 2013 | Intova Ic12 Digital Camera
Tip
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Jan 28, 2008 | Samsung Digimax D53 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
After charging tz3 battery and put in camera it
Are you using the batteries recommended by the manufacturer? that is a very important fact, even though you can find other batteries that have the same specs, they make the cameras to where it will work best, and sometimes only, with the batteries recommended.
May 20, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I bought two new KLIC-8000 for Kodak Z812 IS ..
I bought two new KLIC-8000 for Kodak Z812 IS .. after charging it simple does not start the camera... I tried both the batteries and camera has no response..
Apr 03, 2010 | Kodak EasyShare Z812 IS Digital Camera
Kawasaki Vulcan 900 Custom - sat the winter,
Did you connect the poles correctly and are the bolts tight to keep good contacts?
Try usin a trickle charger to jump the battery.
Mar 21, 2010 | 2005 kawasaki EN 500 Vulcan
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
FL-36 flash
It's my experience that the contacts down at the bottom of the battery compartment corrode easily. Clean them with electronic contact cleaner and a swab and they should work again - for a while.
Aug 05, 2008 | Olympus FL-36 TTL Flash
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Suddenly the batteries have started dying after 2-3 photos
did you try using lithim recharge battery i my self had the same problem with 1sd pentax ithout my camera was naced
Mar 25, 2007 | Olympus Camedia D-580 / C-460 Digital...
Cameras Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
