Question about Candy Washing Machines
How to reset main control board for candy washing machine model cm1612j?
  • Anonymous Mar 21, 2014
    How can we reset a candy washing machine brand evo 1293 as we are trying to start it but we keep getting a lock signal on main board
CANDY CLD 135-86S will not boot, blinking lights two
Posted on Jun 09, 2012
beltronic205
  • 1474 Answers
SOURCE: washing machine starts but trips mains MCB,
Sounds like short or Electrical leakage,,locate and disconnect the heating element then try this goes faulty now and then....Machine should then run /spin fill ...if so fit new heater
Posted on Feb 10, 2011
tiger56h
  • 176 Answers
SOURCE: I have a CANDY ACTIVA
plz tel my the spean is worken
Posted on Sep 11, 2010
  • 11 Answers
SOURCE: circuit board on candy washing machine
you must specif the model of the machine and getme more information
Posted on May 12, 2009
hondo73162
  • 132 Answers
SOURCE: I have a GE washing machine model #WWSE5240GWW the
have you checked the belt, it could be loose or broke
Posted on Oct 28, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
Why does my candy grand o washing machine keep draining and not washing or spinning
sounds like the control board has problem . call repair service
Feb 25, 2017 | Candy Washing Machines
My candy Evo washer is not lighting up and does not work?
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
http://www.partselect.com/Repair/Washer/Will-Not-Start Washing Machine Repair Help
Jan 07, 2017 | Candy Washing Machines
How much does a main drum for a candy washing machine cost
When someone has a drum in stock, it would cost twice the price you pay for a new washing machine. There are no spaceports like this in huge quantities and I think the machine must be some years old. Replacing will cost you a few hours too, so think twice before you start.
Next time, please add the model number too, makes it easier to look for spare parts.
Jan 28, 2015 | Candy Washing Machines
The start/pause button is not working on my candy smart class a washing machine
the pump is blocked up or the filter
once you take the blockage you need to reset the machine
too do this turn off the mains power
press and hold usually the start pause or menu button
and turn the mains on
wait a few seconds and let go
should clear the fault detection
if it is the filter or a blocked bad pump
and its clear then the machine will reset
Oct 09, 2014 | Candy Washing Machines
How do i reset the door lock
make sure its drained out
will open after 5 mins or so
check the filters are not blocked up
and once its clear
hold in the start stop or menu botton and then turn the mains on
to reset the controller
if it still wont open at the end of a test cycle i would assume some blockages it still there
Aug 31, 2014 | Candy Washing Machines
How to reset candy go482
Try unplugging it for 10 minutes and press the start button while it is unplugged and that usually resets the system. If that does not work then you have a board or drain problem.
Aug 02, 2014 | Candy Washing Machines
Hello, I was given a CANDY Smart washing machine CTG 856 but there is no instruction manual. I searched for the manual online but there was none available. Do you know where else can I find one? the main...
hi
the manual for you washing machine is not yet available online but you can request for it to be sent to your mailing address and you will get it shortly.
the link is
http://www.candy.it/libretti/libretto.cfm?lang=2&country=7&brand=candy
Aug 27, 2011 | Candy Washing Machines
Where can you get a circuit board for a candy cn450 washing machine?
I can supply you with a circuit PCB Board for the candy CN450 washing Machine it is £69.50 + P&P £5.95 if you require one you can order from our shop in Market Drayton Appliance World 01630655965
Nov 09, 2009 | Candy Washing Machines
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
1,772 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
