Question about NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS)
Windows XP desktop can connect to home wi-fi network but never acquires an IP address. Other laptops connect to same router no problem. tried both 64 and 128 bit same symptom.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 45 Answers
You remove ip address from desktop & select automatic ip address
Posted on Oct 11, 2010
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
XP laptop will not acquire network address after restarting. It works right after running the setup disk but will not work after a restart. Motorola-6FF0D modem/router connected to Windows 7 desktop. Have...
Pls try this following below and just cool down and read through,
Physical causes and What to Do...
  • Network card could be faulty or malfunctioning, or the port on the card itself. Make sure lights show on the card and if they don't, replace with another one that works.
  • Check that your router or the server is turned on so that the laptop can acquire a valid IP address.
  • Double check to make sure the wireless card on the laptop is turned on. Do not assume it is on by default, do it yourself.
Logical or Software causes and solutions
Many of us are online buyers. Items sold on the internet, especially used items, are not in their default settings. Previous owners do not always reset them before sale, and this causes a lot of issues and unwanted beheaviours. Below are some of the common settings found on Routers:
  • ISP user name and password. If you want to connect to the internet check with your ISP to get your own User name and password, if not ignore this step.
  • Looking at the security options, make sure:
    • MAC address Filtering is not enable. If it is, remove all the MAC addresses on the MAC address table, and enter your Laptop's network card MAC address. With MAC Filtering On, do not forget to enter the MAC addresses of all you wireless devices on to its table.
    • Wireless key settings. Disable the wireless key settings and configure it to meet your requirements.
  • A Laptop to Laptop connection, please make sure the wireless settings on both laptops are the same.
  • Inconsistent wireless Keys. The key on the laptop has to match the one configured on the router.
  • Drivers out of date, update your wireless adapter drivers or your router firmware by checking the manufacturer web site.
  • Wireless not enable on the router. If wireless is not enable on the router, there is no Wi-Fi signal at all. some Router would have wireless turned off by default, and it is the administrator decision to use it or not.
  • DHCP Server misconfiguration. Make sure the DHCP (Dynamic Hosts Configuration) server is properly configured:
    • Enough IP address lease for your network devices
    • The server itself is not down
  • Some simple troubleshooting methods are:
    • Repair the connection. On Windows, click start - Control panel and then Network connections; chose the right connection icon, right then select repair. Windows will, temporarily, disable and re-enable your network adapter to attempt a connection.
    • Reset the IP stack. Click start then Run. At the command prompt type "command" or cmd for short, you are then presented with the command prompt window. Type "netsh int ip reset resetlog", and then restart your Laptop. This applies to desktop computers as well.
    • Reset the router to its factory default. Most routers we use at home are fitted with a reset button, by pressing and hold it for few seconds will bring the router to its factory default. This method solves a lot of the issues mentioned earlier, in one go.
    Nov 10, 2010 | Arris SURFboard SBG900 Wireless Router...
    I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
    Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
    • Move closer to the Wi-Fi router or hotspot.
    • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
    • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
      • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
    After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
    • Check for any sources of potential interference.
    • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
    If you are unable to access the Internet while connected
    • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
    • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
    • Verify that the Wi-Fi network settings are correct:
      • Tap Settings > Wi-Fi.
    • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
    • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
    • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
    • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
    If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
    • Restart the device
      • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
    • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
    • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
    Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
    • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
    • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
    • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
    • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
    • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
    Mar 22, 2010 | Linksys Wireless-G WRT54G Router
    Using Nintendo Wireless Adapter - No Connection Anymore
    If available networks are found, it means that the wireless adapter is working just fine. In case of Wi-Fi, the device has to acquire an IP address from the wireless router and the mutual communication is not taking place. This has something to do with the wireless router. Check for any kind of security filtering like MAC address filtering or lower down the encryption technique to 64-bit WEP. Try connecting to even an unsecured network, then check for the automatically acquired IP address. It should never be starting with 169.254.xx.xx (Invalid)
    If you have other wireless computers going online in the same network, without security and filtering, then it means that your DS Lite is not acquiring an IP address. In that critical case, you may have to statically or manually assign an IP address in the range of the router.
    And lastly, as you said LAN connection is active, it would be because it doesn't face any hardships while connecting!
    Thanks..
    Do get back if you need further clarifications.
    Mar 18, 2010 | Computers & Internet
    The Wifi works (with my laptop) but my desktop
    your laptop is able to go online using WI-FI.
    desktop is connected to theb router but not able to go online. Do you see the port light on the router ?
    check the Ip address on the computer. Check if there is any static IP address on the computer.
    Click here for more information about the router and network
    Jan 20, 2010 | Linksys WRT160N Wireless Router
    Dell dimension 3000 won't see wireless network
    Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
    http://www.behardware.com/articles/614-2/wi-fi-mimo.html
    Pay attention to part about 802.11n compatibility?
    Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
    As to the acquiring ip address message, try using a static ip address, here's a good guide:-
    http://portforward.com/networking/static-xp.htm
    Maybe this will help?
    Jan 27, 2009 | Dell Dimension 3000 PC Desktop
    "acquiring network address" problem
    The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
    Oct 26, 2008 | NetGear WGR614 Wireless Router
    NetGear WNA1100 WirelessN 150 USB Adapter (WNA1100100ENS) Logo
    384 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
