Question about Gigabyte GA-K8VM800M Motherboard
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables inside the board then, what happened is, I got beep sound followed by continous beep..on my next attempt, i am not hearing any beep.. what may be the problem?
    Guru:
  • 124 Answers
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Posted on Oct 12, 2010
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
GA-K8VM800M - No Display
hi it could be your on board gpu these are not changeable, you could also check in the bios weather the first graphics display is the on board one and not an external one, the only way you can do this and also check to see if it is your on board gup is put in an external graphics card if this works then it is possible that your gpu is u/s, but check in bios first it might be just the setting that needs changing....hope this helps
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
1. On board display card is not working 2. When we attach external vga card display is working but no BIOS image in mother board and it gives an error that BIOS image is scan. 3.Key board is not working.
who makes the mother board and what bios is it using? can u access the bios at boot up? if so, is the integrated video option on? have you checked for upgrades / updates for the bios ? if you can access the bios, remove all non integrated devices from the mother board, select the option for "default settings" save and exit. then restart. after assuring the keyboard is plugged in the correct port. it should be color coded.
May 19, 2009 | Gigabyte GA-K8VM800M Motherboard
Hi I just finished building my system my motherboard is a Gigabyte GA-EP45-UD3LR. I have installed 2 seagate sata 500gb harddrives. I spent a lot of time with my bios settings and when the bios gets done...
This is because you either don't have any windows loaded or else the hard disks are not being recognized by the system.
otherwise if windows is present then the MBR Master boot record is damaged.
try reinstalling windows.
Apr 27, 2009 | Intel D845GVSR Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
SHARED VIDEO MEMORY
go to this site http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1810 and download the manual, it should show you how to change the onboard video settings
good luck
Terry
Mar 05, 2008 | Gigabyte GA-K8VM800M Motherboard
System will not boot
bbios updating required + check ur cmos battery too!
Nov 05, 2007 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-K8VM800M Motherboard Logo
157 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
