Question about Curtis Televison & Video
CURTIS DVD1098B HOW CAN I TURN OFF THE BRIGHT BLUE HORIZONTAL BAR LIGHT ON THE FRONT OF MY NEW DVD?
  • pmhutch1938 Oct 11, 2010
    IF NOT TURNED OFF, JUST DIMMER???
    THEY COULD HAVE INCLUDED A MANUAL WITH TYPE BIG ENOUGH TO READ FOR LESS THAN $6 THAT SAID WHAT YOU JUST SAID.
  • 4,472 Answers
Unfortunately that light bar can't be turned off. If it's possible your best bet it to put the dvd player in a location where it isn't as noticeable. That is probably the only downside to this dvd player.
Thank you and enjoy,
Lee
Posted on Oct 11, 2010
  • Lee A.
    Lee A. Oct 11, 2010
    The only way you could dim it is by putting cutting a thin strip of tape and putting it over it, as to not interfere with the ejecting of the tray. Here is a link to the pdf of the manual for all the rest of the features although like i said you can't turn off the light or even dim it for that matter, but that is the only negative thing that can be said as far as the features of the player go.
    http://www.curtisint.com/html/custservic...
    Thanks again,
    Lee
Curtis dvd combo will not turn on
Main board fault. Replace it. Contact any service technician. Gopakumar Gopalan Google
Feb 17, 2014 | Curtis Televison & Video
What video format does a curtis dvd1098b play by usb
I've had so many issues with trying to figure out what format this thing takes via the USB or SD card ports. I mean, for goodness sake's whatever you do don't give that information in the manual lol
After hours and hours I found that it not only depends on the format but the software. I still don't know exactly what the formats are that this things supports but I did finally find a program that produces avi files that play flawlessly on this thing. It's called "FairUse Wizard"
I just keep most everything to default as I'm clicking through the process. The things I did find that needed to be changed were:
1. Choose "Native Mode"
2. Check the "Use TV Display Mode" box
3. Choose 720x480 (others may work as well but this one always turns out with good quality and the file size is quite resonable)
Hope this saves somebody else the hours I spent pulling my hair out on this thing....
Jan 14, 2012 | Curtis DVD1098 Player
How to conect a PROSCAN MODEL 32LB30Q to a curtis DVD1098B
Buy an HDMI cable, plug one end to the Curtis DVD1098B's HDMI Output, and the other end plug into the TV's HDMI IN 1, or 2.
Using the remote control, and the assistance of the manufacturer's manual change the tv's input to HDMI 1, or 2 respectively.
Verify the input, and output of each device if you do not want to use HDMI, then using the same process connect the output of the DVD to the respective Input of the TV, i'm unsure of the TV's input but the television appears to support Component, RCA, and Coaxial.
Mar 01, 2011 | Computers & Internet
My Curtis DVD1098B player will not read a camera SD card. It keeps telling me "bad card". I have tried a couple different cards that function fine in the cameras. How do I fix this?
Use a USB card reader (they only cost $10 if you can find them at biglots or something). I happen to have had one and the SD card is read from that. But the direct slot, the player will say "bad card" also. Cheap player.
Nov 14, 2010 | Curtis Televison & Video
Hi, I have a Curtis DVD 1098B but the blue light where the DVD goes in stays on 24/7 even when the power is off. Annoying! How do I disable it?
you can get rid of that ANNOYING BLUE LIGHT that lights up the dvd tray without damaging dvd player! All you need is a piece of black electrical tape to cover it. There is only one light and it's located on the left side of the tray.
Apr 22, 2010 | Televison & Video
Curtis DVD1098B will not open usb videos from jump drive?
My problem with the USB is that I can see the videos, but there is no sound.
Anyone knows how to fix it?
Nov 10, 2009 | Televison & Video
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
346 people viewed this question
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
