Question about HP Officejet 6310 All-In-One InkJet Printer
Broken hinge How do I fine and buy a replacement hinge for my Hp officejet 6310 ?
  • 2 more comments
  • doordad Jul 12, 2008
    The broken hinge on the left side of the HP 6310 does not allow me to raise the door with the controls on it high enough for it to stay up will replacing cartridge. Also causes door to not close properly unless you push the left side back from the front. It does not appear to be a easy job, hope if I can find one there are directions for replacement.
  • mdg1977 Apr 20, 2009
    I have the same problem
  • Anonymous May 02, 2009
    I was sitting across the room and heard a noise and the hinge broke on the left side of the machine under its own weight, I cannot close the machine now to use it at all
  • Gary Barker
    Gary Barker Aug 23, 2013
    OMG $50.http://www.partshere.com/online/detail.a...
  • 3 Answers
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
Posted on Aug 12, 2010
  • Dennis Harris
    Dennis Harris Mar 12, 2014
    Alternative to the hinge solution, remove the single torsion
  • Dennis Harris
    alternative to the hinge solution above, remove the single torsion screw and remove the bottom black portion of the hinge. Two springs will be attached. Remove the springs. The lid will now set down without putting strain on the good right hinge.
    New Friend:
Simple fix for the broken hinge issue on the HP 6310.
Remove the upper hinges using a torx screwdriver from the unit. Leave the lower hinges in place, including the spring loaded seats. Carefully place the upper section back on the unit to seat in place. Place a length of duct tape across the back on the unit on the join, to act as a new "hinge". With due care the unit functions like new.
Posted on Sep 28, 2014
  • 38 Answers
CAN YOU SEND THE IMAGE FOR THE BROKEN PART
REGARDS
Posted on Jun 06, 2008
Where I can buy hinge No. JB61-00289A?
Sorry to disappoint you. we are a Samsung service center. according to Samsung, that part is no longer available.
Sep 12, 2014 | HP Officejet 6310 All-In-One InkJet...
Motherboard problem?
In general it costs more to repair a printer than to replace it. Spares are not easy to get. Sorry.
Feb 23, 2014 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 repair hinge
Generally the hinge will fall into a groove when lifted up. If it will not close you can generally lift the lid a bit higher and dislodge the hinge from these grooves and it should close.
Oct 19, 2011 | HP Officejet 6310 All-In-One InkJet...
The hinge on the cover cracked. Can this be replaced?
I used an offset cabinet hinge & screwed it into the body of the printer, & the cover. The offset has to be jiggled a bit to open, but works fine on closing.
Otherwise, HP wants you to buy a complete new scanner cover.
Dec 07, 2010 | HP Officejet 6310 All-In-One InkJet...
Left hinge on lid popped out while changing ink cartridge
if its not designed to slide back in, it may be broken. if its broken then you have 3 options:
1. ignore it
2. have it proffesionally fixed
3. get creative (duct tape, super glue, etc)
Nov 30, 2010 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6313 All-in-one: all lights on dashboard and camera icon next to USB and SD ports blink continuously, also continuous message "reset power"
Check the flex cable that connects the carriage assembly to the main board. This flex cable contains about 23 links and you may have a few that are broken. By "carriage assembly", I am talking about that assembly that houses the print cartridges. If you have a few broken links, you can try repairing the cable, but it may be less time consuming to buy and replace the cable.
Dec 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
3,154 people viewed this question
Ben Johnson
