Question about ASUS P4S800D-X Motherboard
Auto restart problem - ASUS P4S800D-X Motherboard
  • 2,574 Answers
Sometimes this can be caused by an overheating situation.If your CPUauto restart problem - mag-glass_10x10.gif is running at over 60 degrees (C) you might be at risk of burning it out. Some systems shut down automatically when the temperature reaches an unsafe level. Every few weeks I open my system unit and clean the fins on the heat sink that sits under the CPU. When they collect dust it restricts the airflow and prevents proper cooling. You can use a can of compressed air (look at your local office supply store) or an old toothbrush. I just did that on my system and the CPU temperature dropped by ten degrees.
Download the free Speedfan utility and it will tell you the temperature at which your CPU and hard drives are running.
If you determine that overheating is not the problem, the most likely suspect is bad memory. Trying to access a bad spot in your system memory (RAM) can cause the computer to freak out and restart. The best way to find the culprit is to pop open the system unit, remove (or replace) one RAM stick and see if the problem is solved. Run your system for a while and if the problem goes away, you win! If not... lather, rinse and repeat for each RAM stick until you find the one that's misbehaving
Computer Restarts After Download?
Some folks have written to me complaining that their computer automatically restarts itself after every download. And interestingly, most (if not all) mentioned they were using the Firefox browser. If you are using a download manager or download accelerator, this could be causing the problem. Check all the settings in the download manager and tweak if necessary. Or get rid of the download manager and see if the problem remains.
This can also be a virus or spyware problem. I suggest you go through your Control Panel / Add or Remove Programs list and remove any programs you don't need, then run thorough anti-virus and anti-spyware scans. It could even be your anti-virus program fighting with the browser or download manager. Switching to a new anti-virus might help also. See my recommendations for the best free anti-virus software for help with that.
Failing or under-rated power supplies can also cause your computer to restart at seemingly random intervals. Switching out a power supply is really not too hard. Turn off the computer, open the case, disconnect the power cable from the power supply to the motherboard. Unscrew the power supply from the case, and reverse the process to install a new power supply. A 300-watt power supply will be fine in most computers.
And as one reader kindly pointed out, bad capacitors on the motherboard can also cause random reboots. But unless you're kinda geeky and handy with a soldering iron, it's tough to identify and fix this problem. You can find lots more helpful info on bad capacitors at badcaps.net. For most mere mortals, replacing the motherboard as a last resort will be easier than replacing a capacitor.
I also encourage you to read ALL of the comments below, before you rip your hair out, or rip your computer to shreds. It boils down to this... most restart problems are caused by overheating, bad ram, malware, or some other failing component. It can be difficult and time-consuming to identify WHICH of those things is the culprit. The only good solution is to test each one, in sequence (removing and replacing components if necessary), to identify the problem.
Posted on Oct 11, 2010
Nokia e72 auto restart problem in 10 sec
Sep 06, 2012 | Nokia E72 Smartphone
Auto off viao leptop
Please do following steps
1)Keep your Laptop In cold region
2)goto Mycomputers>>Right click on mycomputers>>select Properties>>Advanced>>Settings of Startupand recovery tab>>unselected Automatically Restart Option >>apply
Above steps will stop auto restart
If you like solution please Visit VikasTricksonline
Jun 20, 2012 | Computers & Internet
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
Dec 04, 2011 | Samsung SGH-E390 Cellular Phone
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
Nokia 1280 auto restart
i have Nokia N1280 it always auto restart so how can i do ???
Jun 04, 2011 | Nokia 1280 Cell Phone
My nokia x3 auto restart in every five minutes or less
My nokia E63 auto restart in every 5 to 10 sec or less
May 19, 2011 | Nokia X3 Cell Phone
It doesnt turn on. it starts and then auto restart about 3 times and then shuts down.
it doesnt turn on. it starts and then auto restart about 3 times and then shuts down.
Nov 09, 2010 | Nokia 3110 Cellular Phone
Auto restart
look for the control panel then adjust there the configuration of the power system for monitor or for the other system commands. God Speed
Apr 10, 2010 | ASUS Notebook
China mobile cect v180 auto restart
SOMEONE TOLD ME TO GO NERUL STN.
there is one shop named Navi mumbai mobile store he solved the problem
charges 200 rs
Nov 21, 2007 | Cell Phones
ASUS P4S800D-X Motherboard Logo
89 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
