Question about Kitchen Appliances - Others
Tefal Quick Cup
Bought the Quick Cup last yesterday, used it a couple of times very happy with it.
Got up this morning, switched the appliance on at the wall (we always switch off unnecessary appliances overnight), the light comes on red for about 1 second, then goes out. I press the button and nothing, no hot, no room temperature water just nothing comes out.
  • 1 more comment
  • hleece Jun 03, 2008
    tefal br303844 quick cup is 2 months old and has stop heating the water
  • katefosteruk Oct 29, 2008
    got up turned it on blink of red light then nothing..........
  • Anonymous Feb 19, 2009
    I took mine to pieces and it definitely isn't limescale. I can get water to come out now but it still won't heat up. Definitely a manufacturing fault. I think lots of people are getting this problem.
I found that after a few months of use I had to unplug the unit from the mains and plug it back in to reset it. It then ran OK until I wanted to use it again. I took it apart and found that the heating element and temperature sensor (thermistor) were attached to the electronics via copper spring clips. These had formed corrosion where they made contact. A quick clean to the restore the copper colour cured the unit. It now works every time.
Posted on May 26, 2014
As you are getting a light, then the fuse/ supply is ok .
Does it have water in it?
If not, it may be a safety cut out sensing this - and turning off.
Check the manual for any mention of a "thermostatic trip" This may be user-resettable by means of a rod or button underneath, or may need to cool down - you may even hear a click when it does.
If not - then it is likely to be a manufacturing fault within the heating element.
You should be able to return it to the shop you bought it from for a full refund.
Posted on Jun 11, 2008
Tefal quick cup , no water coming out....still a little steam and orange light on...any idea what the problem could be please
Have you cleaned it lately with vinager? Sometimes you have to run it through it to remove the deposited from hard water. It happens to coffee makes an all appliances that use water. Find your instructions an follow what is recommended. If you don't have them you can look them up online.
Jul 19, 2017 | Tefal Irons
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Just bought a tefal quick cup from john lewis and we have lost the instructions, could you tell me how to turn the blue light off on the top when you change the filter . thank you.
Follow this procedure when you change the filter:
Press the hot water button H and the ambient water button G, for at least 5 seconds.
After 5 seconds, the indicator light will go out. The appliance will then have recorded the cartridge change.
If you are happy with my response pease vote for this answer.
Thanks
Mar 05, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal Quick Cup not heating water
press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Dec 15, 2008 | Kitchen Appliances - Others
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
406 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
